Half Life Help
  • Thread starter UWMpanther
[SOLVED] Half Life Help
The activity of a radioisotope is 3000 counts per minute at one time and 2736 counts per minute 48 hours later. What is the half-life of th radioisotope?
This is where I'm completely lost.
Answers and Replies
hage567
1,509
See here for some information:
http://hyperphysics.phy-astr.gsu.edu/hbase/nuclear/halfli2.html#c3
http://hyperphysics.phy-astr.gsu.edu/hbase/nuclear/halfli2.html#c2
You first need to figure out the decay constant (represented by [tex]\lambda[/tex]), which you can do by using the decay equation. Once you have that, you can find the half-life*. The equations you need are in the link. Give it a try and see what you come up with.
*Or you could just substitute the expression for lambda (which relates to the half-life) into the decay equation and solve for the half-life all in one go. Same thing.
[tex]\ln{\frac {[A]_{0}}{[A]_{t}}} = kt[/tex]
[tex]t_{\frac {1}{2}} = \frac {\ln{2}}{k}[/tex]
Take 3000 counts as [tex]A_{0}[/tex] and 2736 counts as [tex]A_{t}[/tex]
Also, do you know how the half-life equation is derived? And what connects these 2 equations?
*don't forget to convert your units.
ok so [tex]\ln{\frac {[A]_{0}}{[A]_{t}}} = kt[/tex] is what I'm going to use to calculate k
and then i use [tex]t_{\frac {1}{2}} = \frac {\ln{2}}{k}[/tex] to calculate for [tex]t_{\frac {1}{2}}[/tex]
Did you get an answer?
yeah I got 21661 mins which then I converted to hours and that is 361 hours.
Looks good to me.
Related Threads on Half Life Help
  • Last Post
10K
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
9K
18K
  • Last Post
12K
