Half-Life of Radioactive Waste: 150,000 Years
  • MHB
  • Thread starter Joystar77
  • Tags
    Half-life
You can then convert to thousand years by dividing by 1000.In summary, the half-life of a particular radioactive waste is the amount of time it takes for half of the original amount to decay. In this case, after 150,000 years, only 1/8 of the original amount remains, indicating that three half-lives have passed. Using the formula for exponential decay, we can solve for the half-life to be approximately 50,000 years. It is important to use consistent units when working with the half-life formula.
Joystar77
125
After 150 thousand years, only 1/8 of the original amount of a particular radioactive waste will remain. The half-life of this radioactive waste is how many thousand years?
150,000 years / 1/8
150,000 / .125
= 1,200,000
If this isn't correct is the 1/8 suppose to be stay as a fraction, turned into a decimal, or turned into a percent? Also, if this isn't correct can somebody explain to me what the term means saying "half-life"?
Mathematics news on Phys.org
Re: Math Word Problem
Since less than half of the original sample is present, you should expect that the half-life is less than the time that has already elapsed.
A quick way to solve this particular problem is to observe that the original amount has been halved 3 times, since \(\displaystyle \frac{1}{8}=\left(\frac{1}{2} \right)^3\), and so we know the half-life is one-third of the elapsed time.
We won't always be presented with a current amount that is a power of one-half times the original amount, so a more general method would be to use:
\(\displaystyle A(t)=A_0\left(\frac{1}{2} \right)^{-\frac{t}{k}}=\frac{A_0}{2^{\frac{t}{k}}}\) where \(\displaystyle 0<k\in\mathbb{R}\) is the half-life.
Now, we are told:
\(\displaystyle A(150000)=\frac{A_0}{8}\)
and so we may state:
\(\displaystyle 2^{\frac{150000}{k}}=2^3\)
Now, equate exponents, and solve for $k$.
Mark FL,
What shows up in my email as you working out this word problem shows something totally and completely different. I know obviously the problem that I worked out was wrong, but the question I asked was does the 1/8 stay as a fraction or be turned into a decimal or percent?
Here is what was sent to my email:
A quick way to solve this particular problem is to observe that the original amount has been halved 3 times, since \frac{1}{8}=\left(\frac{1}{2} \right)^3, and so we know the half-life is one-third of the elapsed time.
A(t)=A_0\left(\frac{1}{2} \right)^{-\frac{t}{k}}=\frac{A_0}{2^{\frac{t}{k}}} where 0<k\in\mathbb{R} is the half-life.
Now, we are told:
My understanding of this math problem than what shows on this site seems to be a little different. Which is suppose to be the correct way?
What was sent to you by email is the text minus the MATH tags.
As you can see by this line:
I left the 1/8 as a fraction, since 8 is a power of 2, it made the last step easier. But suppose, instead we were told 1/10 of the original was left, then we would have:
\(\displaystyle 2^{\frac{150000}{k}}=10\)
I try to use rational numbers rather than decimal representations whenever possible. I just prefer that form.
Taking the natural logarithm of both sides, we would find:
\(\displaystyle \frac{150000}{k}\ln(2)=\ln(10)\)
Now, solving for $k$, we find:
\(\displaystyle k=\frac{150000\ln(2)}{\ln(10)}\approx45154.49934959717\)
Does it make sense to you that if the elapsed time is held constant, but the amount left is decreased, then the half-life decreases as well? A smaller half-life means the substance decays at a quicker rate.
150,000 years / 1/8
150,000 / .125
= 1,200,000
half-life is the amount of time it takes for half a given substance to decay. It needs a large sample size so the law of large numbers can be used.
  • At the start you have a fraction of 1 remaining (none has decayed)
  • After one half-life you have 0.5 remaining
  • After two half-lives you have 0.25 remaining
If you use the powers of two you have (where H/L is half-life for brevity's sake):
  • Start = \(\displaystyle 2^0\)
  • One H/L = \(\displaystyle 2^{-1}\)
  • Two H/L = \(\displaystyle 2^{-2}\)
There is a pattern here: after n half-lives you have \(\displaystyle 2^{-n}\) left of the original amount.
If you know that \(\displaystyle \dfrac{1}{8} = 2^{-3}\) you can say that three half-lives have passed in those 150,000 years so one half-life must be one-third of the 150,000 years that have passed.
More generally you can use the formula for exponential decay
\(\displaystyle A = A_0e^{-t / t_{1/2}}\) where:
  • \(\displaystyle A\) is amount remaining at time \(\displaystyle t\)
  • \(\displaystyle A_0\) is amount when \(\displaystyle t=0\)
  • \(\displaystyle t\) is time
  • \(\displaystyle t_{1/2}\) is the half-life
We know that:
  • \(\displaystyle A = 0.125A_0\)
  • \(\displaystyle A = A_0\)
  • \(\displaystyle t = 150,000\)
You can then plug in those values and find \(\displaystyle t_{1/2}\)
\(\displaystyle 0.125A_0 = A_0 e^{-150000/t_{1/2}}\)
A quick note on units: You can use any unit of time you like as long as your half-life and time share the same unit. Your value will come out in years if you apply the formula above.
What is the half-life of radioactive waste?
The half-life of radioactive waste refers to the amount of time it takes for half of the original radioactive material to decay into a stable form. In the case of radioactive waste with a half-life of 150,000 years, it means that after 150,000 years, only half of the original radioactive material will remain.
What makes radioactive waste dangerous?
Radioactive waste is dangerous because it emits radiation, which can cause harm to living organisms. This radiation can damage cells and DNA, leading to health issues such as cancer and genetic mutations. Additionally, radioactive waste can remain hazardous for hundreds of thousands of years, making it a long-term threat to the environment.
How is radioactive waste stored?
Radioactive waste is stored in specialized facilities designed to contain and isolate the waste from the environment. These facilities use multiple layers of barriers, such as thick concrete walls, to prevent the escape of radiation. Some types of radioactive waste may also be stored in deep underground repositories to further reduce the risk of exposure.
What are the risks of storing radioactive waste for such a long time?
One of the main risks of storing radioactive waste for a long period of time is the potential for leaks or breaches in the storage facilities. If the waste were to escape into the environment, it could contaminate the surrounding area and pose a threat to living organisms. Additionally, the cost and responsibility of maintaining and monitoring the waste for thousands of years pose a significant challenge.
What are some potential solutions for dealing with radioactive waste?
Some potential solutions for dealing with radioactive waste include long-term storage in specialized facilities, reprocessing the waste to reduce its volume and radioactivity, and developing advanced technologies for safely disposing of and neutralizing the waste. Another solution is to reduce the production of radioactive waste by using alternative energy sources and implementing more efficient nuclear power plant designs.
  • Astronomy and Astrophysics
  • General Math
