I Hamiltonian in QM for QFT forces/fields effects
  • Thread starter jlcd
What makes you think this?
This thread is actually clarifications from a post you were discussing with Demystifier and someone called Electric to be (in two threads):
Post 1: "(One point that I have not raised is that the wave function is not the only "structure" present in QM; there is also the Hamiltonian, or Lagrangian if you are doing QFT. So one possibility that we have not discussed is that the "additional structure" is in the Hamiltonian, not the wave function; that the Hamiltonian of the cat, or the cat/environment system, is what picks out the alive/dead basis as the one that gets decohered.)"
Reference https://www.physicsforums.com/threads/irreversibility-vs-reversibility.909761/page-2#post-5734686
Post 2: "In QM the quantized Hamiltonian is still used to find the total energy in these situations It's the operator corresponding to the "energy" observable, yes. But this observable only measures the energy in the "system", i.e., the part that we are modeling using QM. It can't tell you anything about the part that we are not modeling using QM, i.e., the field. So if you consider the field as part of "the total system", then you would have to say that "the total system" is not completely modeled by QM in this case, so the "energy" you get from the QM operator is not the "total energy"."
Reference https://www.physicsforums.com/threads/hamiltonian-in-quantum-vs-classical.919627/page-2
In the second post, you stated how the "field" was not part of the QM hamiltonian. So if the additional structure is in the "field". Then it is not part of the Hamiltonian you were describing in post 1? If it's the field that is the source of the additional structure, then the right language is to say the Lagrangian of QFT couldbe the source of the additional structure that gives the preferred basis of unitary only dynamics?
24,312
5,990
Ok. It would have been really, really helpful if you had said this and given the links in the first post in this thread. See below.
No, that's not what I said. I said that (in the particular model under discussion, which was non-relativistic QM using the Schrodinger Equation) the field was not part of the "system" whose energy is described by the Hamiltonian operator--i.e., the wave function. The field in that case is certainly part of the Hamiltonian, since it contributes to the potential energy that appears in that Hamiltonian. But that potential energy is the potential energy of the particle whose wave function the equation gives the dynamics for; it's not the potential energy of the field.
In other words, we have been going around in circles in this thread because your original motivation for starting it was that you had a simple misunderstanding of something I said in a post in a previous thread. That's why it would have been really helpful if you had linked to that post when you started this thread, so we could have figured all that out sooner.
Thread closed.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
