How Does the BCS Hamiltonian Describe Superconductivity?
In summary: You are summing over all values of p and p', so the sum over a^\dag_p a^\dag_{-p'} is the same as if you write down a^\dag_p a^\dag_{p'}. So the sum also includes the term you mention. It includes all possible pairs of momentum at this stage.
Petar Mali
290
[tex]\hat{H}_{BCS}=\sum_{\vec{p},\sigma}\epsilon(\vec{p})\hat{a}^+_{\vec{p},\sigma}\hat{a}_{\vec{p},\sigma}+\sum_{\vec{p},\vec{p}'}V(\vec{p},\vec{p}')\hat{a}^+_{\vec{p}\uparrow}\hat{a}^+_{-\vec{p}\downarrow}\hat{a}_{-\vec{p}'\downarrow}\hat{a}_{\vec{p}'\uparrow}[/tex]
What is the meaning of the terms [tex]\hat{a}^+_{\vec{p}\uparrow},\hat{a}^+_{-\vec{p}\downarrow}[/tex]... ?
If I work mean- field approximation
[tex]\hat{H}_{BCS}=\hat{H}_0+\hat{H}_2+\delta\hat{H}[/tex]
What is the procedure to find terms [tex]\hat{H}_0[/tex], [tex]\hat{H}_2[/tex], [tex]\delta\hat{H}[/tex]?
And what is meaning of
[tex]\sum_{\vec{p},\sigma}\epsilon(\vec{p })\hat{a}^+_{\vec{p},\sigma}\hat{a}_{\vec{p},\sigma}[/tex]
and second part of the Hamiltonian! Second part is some interraction.
Can I say that
[tex]\hat{a}^+_{\vec{p},\sigma}=\hat{a}^+_{\vec{p}}\hat{\xi}_{\sigma}[/tex]?
The a's are creation operators (the one with the daggers). They create an electron with momentum p and spin up or down.
The usual procedure in BCS theory is to determine the V(p,p') dependence. You'll notice that the relevant contributions come from the V(p,-p) terms (which is the reason why electrons with opposite momentum are paired up).
Can I say that
The first term can be seen as the energy carried by an electron. The summation over [tex]a^\dag a[/tex] counts the number of electrons, and the epsilon is the energy packket carried by each electron. You can see view it as sort of a kinetic energy term.
You cannot make that replacement, since [tex]a^\dag[/tex] is an operator which creates an electron with momentum p and spin sigma.
Thanks for you're answer. Just to ask in this product of four operators you have [tex]\hat{a}^+_{\vec{p}\uparrow}[/tex] and [tex]\hat{a}^+_{-\vec{p}\downarrow}[/tex] so
[tex]\hat{a}^+_{\vec{p}\uparrow}\hat{a}^+_{-\vec{p}\downarrow}[/tex]
Why you don't have product of [tex]\hat{a}^+_{\vec{p}\uparrow}[/tex] and [tex]\hat{a}^+_{\vec{p}\downarrow}[/tex] so
[tex]\hat{a}^+_{\vec{p}\uparrow}\hat{a}^+_{\vec{p}\downarrow}[/tex]
And I can't see when I look this Hamiltonian where are Cooper pairs?
You are summing over all values of p and p', so the sum over [tex]a^\dag_p a^\dag_{-p'}[/tex] is the same as if you write down [tex]a^\dag_p a^\dag_{p'}[/tex]. So the sum also includes the term you mention. It includes all possible pairs of momentum at this stage.
What's more important is the function V(p,p'). It's this formula that determines what the interaction energy is between two electrons - one carrying momentum p and one carrying momentum p'. What makes BCS theory so special, is that you can show that the function is peaked around V(p,-p). I.e. the binding energy between two electrons carrying opposite momentum is the largest contributions to the system.
Why this is so: well, you have to look up what the exact shape is of V(p,-p) (it included integrating over the degrees of freedom from the phonon-electron interaction -- very complicated stuff). So no, you cannot see from this Hamiltonian why there are Cooper pairs. You need the exact shape of V(p,p)
You wanted to say that Hamiltonian I wrote is the same as the Hamiltonian
[tex]
\hat{H}_{BCS}=\sum_{\vec{p},\sigma}\epsilon(\vec{p })\hat{a}^+_{\vec{p},\sigma}\hat{a}_{\vec{p},\sigma}+\sum_{\vec{p},\vec{p}'}\hat{a}^+_{\vec{p}\uparrow}\hat{a}^+_{\vec{p}\downarrow}\hat{a}_{\vec{p'}\uparrow}\hat{a}_{\vec{p}'\downarrow}[/tex]
Can I treat this like
first sum - the kinetic energy of electrons
second sum - creation Cooper pair in state with impulse [tex]\vec{p}[/tex] and anihilation Cooper pair in state with impulse [tex]\vec{p}'[/tex]
Yes, this new Hamiltonian is an approximation to the original one.
For a treatment on this see Tinkham - Introduction to superconductivity, chapter 3
Is it easy way to get [tex]\hat{H}_0,\hat{H}_2,\delta\hat{H}[/tex]
where [tex]\hat{H}_0+\hat{H}_2=\hat{H}_{MF}[/tex] ?
1. What is the Hamiltonian of BCS theory?
The Hamiltonian of BCS theory is a mathematical representation of the total energy of a superconductor system. It includes terms for the kinetic energy of the electrons, the attractive interactions between electrons, and the energy of the superconducting condensate.
2. How is the Hamiltonian of BCS theory derived?
The Hamiltonian of BCS theory is derived using the Bardeen-Cooper-Schrieffer (BCS) theory of superconductivity, which explains the phenomenon of superconductivity as a result of the formation of electron pairs. The Hamiltonian is obtained by solving the BCS equations, which describe the behavior of the electron pairs in a superconductor.
3. What do the terms in the Hamiltonian of BCS theory represent?
The first term in the Hamiltonian represents the kinetic energy of the electrons, which is the energy associated with their motion. The second term represents the attractive interactions between electrons, which allow for the formation of electron pairs. The third term represents the energy of the superconducting condensate, which is the energy associated with the coherent movement of the electron pairs.
4. How does the Hamiltonian of BCS theory explain superconductivity?
The Hamiltonian of BCS theory explains superconductivity by showing how the formation of electron pairs and the development of a superconducting condensate leads to a state of zero resistance and perfect conductivity. This occurs when the energy of the superconducting condensate is lower than the energy of the normal state, allowing for the electrons to move freely without encountering any resistance.
5. Are there any limitations to the Hamiltonian of BCS theory?
While the Hamiltonian of BCS theory has been successful in explaining many aspects of superconductivity, it has some limitations. It does not take into account certain factors such as disorder and impurities in the superconductor, which can affect the behavior of the electron pairs. Additionally, it does not fully explain the phenomenon of high-temperature superconductivity, which is still an active area of research.
  • Atomic and Condensed Matter
  • Quantum Physics
  • General Math
  • Quantum Physics
