Does Momentum Affect Potential Energy in a Particle Box?
In summary, the potential energy in a box takes into account the position of the particles, but not their momentum. The momentum operator is not well-defined for the particle in a box Hilbert space. In the Schrodinger Equation, the momentum operator is important for solving for the canonical momentum and is the generator for spatial translations. However, for a particle in a box with rigid boundary conditions, the momentum operator is not self-adjoint and the Hamiltonian is used to represent the energy of the particle.
  • #36
vanhees71 said:
Have you ever read a real textbook on QT? To write down the most simple Hamiltonian in atomic physics (the hydrogen atom) you need already momentum:
$$\hat{H}=\frac{\hat{\vec{p}}_1^2}{2m} + \frac{\hat{\vec{p}}_2^2}{2M} -\frac{e^2}{4 \pi |\hat{\vec{x}}_1 - \hat{\vec{x}}_2|}.$$
Here ##\vec{p}_1## and ##\vec{p}_2## are the momenta of the electron and the proton and ##\hat{\vec{x}}_1## and ##\hat{\vec{x}}_2## their position vectors, respectively.
While it is generally agreed potential is independent of momentum. But how come potential+kinetic is no longer independent to momentum as you showed above?
Yes, in my expression the potential is indeed independent of momentum, it's the Coulomb potential between two point particles. I can only again strongly advice to go back and first learn classical mechanics up to and including the Hamiltonian formulation. The goal must be to have a very good understanding of Poisson brackets and basics of Lie algebras and groups. Then you can attach quantum theory again, e.g., with a textbook like Sakurai.
What you mean it's the Coulomb potential between two point particles? Why did you include Coulomb here.
Yes. I agree I need to first get good handle of classical mechanics up to and including the Hamiltonian formulation. What would be a good book about this.
To solve the energy eigenvalue problem, what you indeed only need to know are the commutation relations between these quantities. Pauli solved the hydrogen problem within matrix mechanics by knowing the classical physics of the problem very well, making use of the large dynamical symmetry and the Runge-Lenz vector.
Schrödinger solved the same problem, using his wave mechanics, which was more within the mathematical standard techniques of the physicists at his time, i.e., he wrote down the energy eigenvalue problem in terms of the partial differential equation, which we now call the "time-independent Schrödinger equation". For this he needed to know that in the position representation the momentum operators are ##\hat{\vec{p}}_1=-\mathrm{i} \hbar \vec{\nabla}_1## etc.
  • #37
Um, because kinetic energy is not independent of momentum? Isn't that obvious?
The potential due to the Coulomb interaction (i.e., static electric field) between two point particles.
  • #38
stevendaryl said:
The phrase "solve for momentum of atoms" doesn't mean anything to me. Why do you think anyone solves for the momentum of atoms? What does "solve for the momentum of atoms" mean?
You keep explaining one statement in terms of another statement that doesn't make any sense.
As far as I know, "solving for momentum" and "solving for the momentum observable" and "solving for the momentum of atoms" and "solving for the momentum of observables" are equally mysterious. I don't know what you mean by any of them. You're asking why people do something, and that something is something that, as far as I know, nobody does.
It's as if I asked you: "Why take the square-root of a banana?"
Let me clarify something (this is for Vanhees71 too) . According to Vanhees71. "As for any other observable, if you know the quantum state of the atom you can calculate the probability for finding the momentum of this electron within a certain range, it's given by the momentum-space wave function via Born's rule.". Is this not the same as the statement:
1. solving for momentum
2. solving for the momentum observable
3. solving for the momentum of observables
Isn't the mere calculating the probability for finding the momentum of this electron within a certain range also referred to as "solving for momentum" or "solving for momentum observables?" I've been pondering about this semantic nitpicking.. so I need to know what is wrong with the description or language.
  • #39
It is not nitpicking. It is trying to understand what you mean. "Solving for momentum" is generally something you might do in classical physics where it has a particular value. The way you are applying it here is not standard and so you have several experienced physicists trying to figure out what you are actually trying to accomplish.
Likes vanhees71
  • #40
May i know why would anyone want to calculate the probability for finding the momentum of this electron within a certain range as given by the momentum-space wave function via Born's rule. What would you do with the momentum information? What further or other computations where you first need to have the momentum probability information? Thanks.
  • #41
I don't know. It was you asking about the momentum, although in a way that we had to guess what you might mean. We cannot teach you basic QT in this forum. So please, first read a good book on QT (e.g., Sakurai).
  • #42
And with that, this thread is closed.
Likes vanhees71
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
