• Support PF! Buy your school textbooks, materials and every day products Here!
Hammer and nail
  • Thread starter LuckyIam
Hey everyone, this is a copy/paste from a another thread. I actually don't need help with finding an answer. Its a practice problem in the book so its all worked out. What I need is for someone to help explain to me why the normal force is the average...I'm having trouble understanding this part
1. Homework Statement
In a pile driver , a steel hammerhead with mass 200kg is lifted 3m above the top of a vertical I beam being driven into the ground. the hammer is then dropes driving the Ibeam7.4cm farther into the ground. The vertical rails that guide the hammerhead exert a constant 60N friction force on the hammerhead. Use the work energy theorem to find a) speed of the hammerhead just as it hits the I beam andb) the average force the hammerhead exerts on the I-Beam Ignore the air effects of the air.
3. The Attempt at a Solution
I managed to understand part a. Part b is where I am lost.
The book shows the following work, and I need help understanding on of the steps.
Wtotal = (w-f-n)s23
Wtotal = (w-f-n)s23 = k3-k2
*** n is the same as g right? and we solve for n? Since when is n the average force?***
n = w-f - k3-k2/s23
=1960N - 60N - 0J - 5700J / 0.074m
=7900N
the part underlined I understand.
The part in bold is where I can't explain why.
Read more: https://www.physicsforums.com
BvU
12,488
2,799
Good.
Well, let me guess: 2 is when the hammer hits, 3 is when the 7.4 cm are done. s23 is then the 0.74 m.
So what you have is some kind of energy equation:
Ekin, 2+Epotential, 2 = Workbeam + Workfric +Epotential, 3
with Workbeam the energy used to drive the I beam down
and Workfric the energy lost in friction.
Workbeam is s23 * average force, hence the average force.
Your answer is a factor 10 off - or you made a typo.
Probably forgot the brackets in
1960N - 60N - ( 0J - 5700J ) / 0.074m
AND a zero in the result.
That makes it time-consuming to help you !
Have pity with the poor helpers who desperately try to understand what you type: read what you typed as if you were one of them.
Related Threads for: Hammer and nail
  • Last Post
15K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
  • Last Post
12K
