How Do You Calculate Distances and Angles for Multiple Treasure Map Routes?
In summary: N Then walk 5 m E: E 5 W 7 Then turn 90° and walk 13 m E:
XPX1
55
A treasure map directs you to start at a palm tree and walk due north for 12.0 m. You are then to turn 90° and walk 13.0 m; then turn 90° again and walk 5.00 m. For each of the four possible locations of the treasure, give the distance from the palm tree and the direction, expressed as an angle measured counterclockwise from north. List the possible locations in counterclockwise (CCW) order, starting with the one which is closest to due east.
14.76m and ° (location which is farthest east)
_____m and ° (next location in the CCW direction)
Hello, I am completely lost with this question, here is the steps I did to get the first answer, 14.76m with is correct.
I am supposed to walk north 12m, y = 12, then I turn 90 degrees and walk right for 13m x = 13 then I turn 90 degrees and walk back down 5m. So y = 12-5=7 because I walked up 12m and then back down 5 meters and x = 13.
Knowing this I can construct a triangle
x=13
_____
y=7 | /
|_/
a^2+b^2=C^2
13^2+7^2 = 218
Square root of 218 is 14.764, so the answer to the first question is 14.764, but how do I figure out the degrees for it counterclockwise, and find the rest of the answers for the problem? I tried setting x negative since I could walk left, but that did not give me a correct answer for one of them, please help!
Your overcomplicating things, I assume the treasure is located at each point turning point. The first treasure point (third on your list) is the easiest it's located at 12m and 0°, when it says turn 90° your are turning on a right angle to your right.
12m and 0 degrees was wrong :( I still don't quite understand
Palm tree has the co-ordinate (0m,0m)
1) you travel 12m North new co-ordinate (12m,0m)
2) turn 90° (due east) you walk 13m new co-ordinate (12m, 13m)
3)turn 90° (due south) you walk 5m new co-ordinates (7m,13m).
You have worked out the distance correctly, do you know the trigonometric relations?
Not really, all I know is that I am confused, and I know what Sin Cos Tan and Tan -1 do
[tex]tan /theta = x/y[/tex]
Im still lost. I know how to do the first part for meters, but I do not know how to get the degrees, or anything else, and none of this stuff above is making sense?
tan/Theta = x/y? what does that give me though? does it tell me how many meters I am supposed to go to get the treasure? or the degrees needed for the answer? both? I am confused.
Can someone please tell me how to get the answers for the questions above just plain and simple, all this other stuff doesn't seem to fit into the problem I am being asked. Its not asking about where I am at in just meters, its asking where I am at in meters and next location in degrees in the counterclockwise direction
bump for great justice
I assume the "possible locations" is because you aren't told whether you turn left or right at each point. You turn twice and since at each turn you have 2 choices: right or left- so there are 2(2)= 4 possible answers.
Don't use triangles or trigonometry until after you have found the final position- just keep the N-S and E-W distances separate. I'm going to use + for N or E, - for S or W:
Assuming you turn right both times:
First walk 12 m N: NS 12 EW 0
turn right walk 13 m E: NS 12 EW 13
turn right walk 5 m S: NS 12- 5= 7 EW 13
From your original position you know have a right triangle with legs of length 7 and 13 m. Use the Pythagorean theorem to find the length of the hypotenuse (distance from original point to final point) and use
tan[itex]\theta[/itex]= 7/13 to find the angle.
Turn right first time but left second time:
turn left walk 5 m N: NS 12+ 5= 17 EW 13
You now have a right triangle with legs of length 17 and 13. Again use the Pythagorean theorem to find the distance, tan[itex]\theta[/itex]= 17/13 to find the angle.
Turn left first time, right second time
turn left walk 13 m W: NS 12 EW -13
turn right walk 5 m S: NS 12- 5= 7 EW -13
You again have legs of length 7 and 13 (length is always positive) so the same distance as before but now tan[itex]\theta[/itex]= -7/13.
Turn left both times
turn left walk 5 m N: NS 12+ 5= 17 EW -13
Now you have a right triangle with legs of length 17 and -13 so the same distance as before but the angle is given by tan[itex]\theta[/itex]= -17/13.
What is a "Hard Direction Question"?
A "Hard Direction Question" is a type of question that requires a specific answer or direction to be given. It is usually used in problem-solving scenarios and requires critical thinking skills to answer.
What makes a question a "Hard Direction Question"?
A "Hard Direction Question" is characterized by its specific and targeted nature. It often includes keywords such as "how", "why", "what", or "which", and requires the person to provide a clear and precise answer or direction.
How do I approach a "Hard Direction Question"?
To successfully answer a "Hard Direction Question", it is important to carefully read and understand the question, identify the keywords and key concepts, and take your time to think critically about the answer. It may also be helpful to break down the question into smaller parts and brainstorm possible solutions.
What are some common mistakes when answering "Hard Direction Questions"?
One common mistake is not fully understanding the question and providing an incorrect or incomplete answer. Another mistake is not reading the question carefully and missing important details or keywords. It is also important to avoid making assumptions and to provide evidence or logical reasoning to support your answer.
How can I improve my skills in answering "Hard Direction Questions"?
Practice is key to improving your skills in answering "Hard Direction Questions". You can also try seeking help from others, breaking down questions into smaller parts, and learning from your mistakes. Additionally, working on your critical thinking and problem-solving skills can greatly aid in effectively answering these types of questions.
