Solving Hard Inequalities: 1/(x+4)>x-4 & 1/(x+7)>x-7
In summary, the conversation discusses solving equations with fractions and using the rule "0 > (x-a)(x-b)(x-c) with a<b<c" to determine the possible values of x. The method of multiplying both sides by the square of the denominator is also suggested as an easier approach. The conversation ends with gratitude for the help provided.
alewisGB
I am looking at questions like
1/(x+4)>x-4
or 1/(x+7)>x-7
I have no idea how to solve them,
I have simplified to (-x^2+50) /(7+x)
however I don't think it is correct and I don't know what do do from there.
hi alewisGB! :smile:
(try using the X2 button just above the Reply box :wink:)
obviously, you need to get rid of the fraction!
in an ordinary equation, you'd just multiply both sides by the denominator
but that might be negative (which would change the > to <),
so, instead, multiply both sides by the square of the denominator …
what do you get? :smile:
for:
1/(x+2)>x-2
Step 1: x+2>x3+2x2-4x-8
Step 2: 0>x3+2x2-5x-10
Step 3: 0>(x+2)(x2-5)
Step 4: if 0=(x+2)(x2-5)
x = -2 or +√5 or -√5
Step 5: Unsure, do input -2.01 and -1.99 and see which one is true? (same for +or-√5) or do I do something else
this way is easier :wink:
1/(x+2)>x-2
Step 1: x+2>(x+2)(x2-4)
Step 4: 0>(x+√5)(x+2)(x-√5)
… and you now have this in the form 0 > (x-a)(x-b)(x-c) with a<b<c,
sooo … ? :smile:
I have got the answer of -√5 > x and 5 > x > -2
I have not done further maths and although inequalities were covered they were not nearly this complex
I have not seen the rule "0 > (x-a)(x-b)(x-c) with a<b<c"
So I am not sure what that means
Thank you for your help :)
oh, that's easy
the RHS is the product of three numbers,
and it can only be negative if one or all three of them are negative,
which means either x < a or b < x < c :wink:
Thank you ever so much, you have no idea how grateful I am. This will help me in now but also in the future :)
1. What is the general approach to solving hard inequalities?
The general approach to solving hard inequalities is to use algebraic manipulation and properties of inequalities to isolate the variable on one side of the inequality sign and find the range of values for which the inequality is true.
2. How do I solve an inequality with fractions?
When solving an inequality with fractions, you should multiply both sides of the inequality by the least common denominator (LCD) to eliminate the fractions. This will result in an equivalent inequality without fractions, which can then be solved using traditional methods.
3. What are the key properties of inequalities that can be used to solve them?
The key properties of inequalities that can be used to solve them include:
  • Adding or subtracting the same number to both sides of the inequality
  • Multiplying or dividing both sides of the inequality by the same positive number
  • Flipping the inequality sign when multiplying or dividing by a negative number
  • Combining like terms to simplify the inequality
4. How do I know if my solution to an inequality is correct?
To check if your solution to an inequality is correct, you can substitute the value you found for the variable back into the original inequality and see if it satisfies the inequality. If it does, then your solution is correct. If not, you may need to check your work or try a different approach.
5. Can I graph an inequality to help solve it?
Yes, you can graph an inequality to help visualize the solution and check your work. To graph an inequality, you can first graph the corresponding equation, then shade the region above or below the line depending on the inequality sign. The solution will be the shaded region on the graph.
