Hard Related Rates Problem
  • Thread starter bobraymund
Problem solved :)
Answers and Replies
Looks good.
Really?? Haha, I had no idea what I was doing, honestly. If someone could double check my work, that'd be awesome. I know this is asking alot. :p
I worked it out myself. Everything is correct. I would add a couple of notes about part c: You might want to switch your calculator to radian mode if you used a calculator to find arctan (5/12) just to be on the safe side. IMHO, there is never really any reason to choose to work in degree mode unless a problem is written that way or the answer needs to be in degrees. Also, it seems like you used the diagram to obtain the exact value of sec2 [tex]\Theta[/tex]. That was a good choice (better than using any decimal approximation you obtained earlier). Also, not that it matters, but you could express 1/sec2 [tex]\Theta[/tex] as cos2 [tex]\Theta[/tex] if it would make it simpler for you to work with.
Everything was correct, but I wanted you to be able to see these things. Good Job.
Thanks Bear B for the input. Yeah, I caught myself doing it in DEG, because I was previously using it for my physics homework.
That is interesting that you point out I could have used the diagram to find the value of sec^2... I didn't do that, but just did right now and obtained the same answer. Thanks for pointing that out though, very interesting.
Thanks everyone. :)
In the future I recommend not editing your original post so that the problem disappears. While you are done being helped, there's some chance that someone else might be able to learn something from the discussion of your problem.
Related Threads on Hard Related Rates Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
