1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Hard thinking questions
  1. Oct 21, 2010 #1
    a) given, a + 5 and 2a-1, one is 40% greater than the other one, solve for a.
    b) given, 5x[tex]^{4}[/tex] + 4x[tex]^{3}[/tex] + 3x[tex]^{2}[/tex] + Px + Q. When divided by x[tex]^{2}[/tex] - 1, you get a remainder of 0, solve for p and q.
    c) given csc(6b + [tex]\frac{pi}{8}[/tex]) = sec(2b - [tex]\frac{pi}{8}[/tex]), solve for b.
    2. Relevant equations
    3. The attempt at a solution
    please help, i can't get started on these three at all... :confused:
    edit:
    c) i know that cscx = 1/sinx and secx = 1/cosx, i then cross multiplied to get [tex]cos(2b-pi/8) = sin(6b+pi/8)...
  3. Oct 21, 2010 #2
    Question a) shouldn't be a problem at all.
    Any attempt by you ?
  4. Oct 21, 2010 #3
    Would it be (a+5) = .4(2a-1) + 2a-1 ? or .4(a+5) + (a+5) = 2a - 1 ?
  5. Oct 21, 2010 #4
    It's not clear from the text. Choose one and go on, or solve both in sequence.
  6. Oct 21, 2010 #5
    well then you get a+5 = 0.8a - 0.4 + 2a -1
    a+5 = 2.8a - 1.4
    1.8a - 6.4 = 0
    1.8a = 6.4
    a = 3.55555556 :confused:
    or
    2a - 1 = .4a + 2 + a + 5
    2a - 1 = 1.4a + 7
    0.6a - 8 = 0
    0.6a = 8
    a = 13.3333333
    therefore a can be 13.333 or 3.555 ? :confused:
  7. Oct 21, 2010 #6
  8. Oct 21, 2010 #7
    thanks :smile: could you help me get started on b) ?
    Thanks for your time!
  9. Oct 21, 2010 #8
    b)
    Make this multiplication [tex] (x^2-1)(Ax^2+Bx+C)[/tex]
  10. Oct 21, 2010 #9
    that would give you [tex] ax^4 + bx^3 + (c - a)x^2 - bx - c[/tex]. Is that what you mean?
  11. Oct 21, 2010 #10
    Ok, so now give the solution. It's really easy.
  12. Oct 21, 2010 #11
    do you use the original equation? so a = 5, b = 4, and c = 3?
    but that doesn't work... cause then you get:[tex]5x^4 + 4x^3 + (3 - 5)x^2 - 4x - 3[/tex]
  13. Oct 21, 2010 #12
    You realize by yourself there's something wrong. Ok.
    You should come alone to the solution. The next step would be giving you the solution.
  14. Oct 21, 2010 #13
    I don't see what I could possibly do to get the answer :confused: I know that c - a = 3, that's all... but c itself is 3 :confused:
  15. Oct 21, 2010 #14
    Why you say "c itself is 3"... ???
    Tell me where is written that ?
  16. Oct 21, 2010 #15
    oh, well i based it on the original... a = 5, b = 4, c = 3...
    well, then if that's the case,
    [tex]ax^4 + bx^3 + (c - a)x^2 - bx - c[/tex]
    [tex]=5x^4 + 4x^3 + (c - 5)x^2 - 4x - c[/tex]
    therefore
    [tex]
    c = 8 [/tex]?
    and therefore:
    [tex]P = -4[/tex]
    [tex]Q = -8[/tex]
    is that what you meant?
    Thanks for your help! Means a lot!
  17. Oct 21, 2010 #16
    Not quite....
    You solve for the cases where one term is 40% of the other, not 40% greater then the other, as the question asked!
    In other words, suppose you have a number (let's say 20) and you want to find the value that is 40% greater.
    0.4 * 20 = 8 which is clearly not 40% greater. In fact, it is less!
    What would you do to determine the value that is 40% greater than 20?
  18. Oct 21, 2010 #17
    Well you would do .4 * 20 + 20, a value 40% greater then 20 is 28?
  19. Oct 21, 2010 #18
    Yes, but that simplifies...
    0.4 * 20 + 20 = (0.4 + 1) * 20 = 1.4 * 20
    Therefore, a number that is 40% larger than x is 1.4 * x
  20. Oct 21, 2010 #19
    well at first glance (and i do mean i only "glanced" at it for a split second), i thought the same thing...here are the equations he set up:
    look closer at the right-hand side of the first equation. 0.4(2a-1) + 2a-1 = 1.4(2a-1), and the original equation becomes a+5 = 1.4(2a-1), which certainly implies that a+5 is 40% larger than 2a-1. likewise, we can see that the left-hand side of the 2nd equation, 0.4(a+5) + (a+5), equals 1.4(a+5). and so equation 2 becomes 1.4(a+5) = 2a-1, which certainly implies that 2a-1 is 40% greater than a+5.
    your calculations are correct - you just chose to represent the quantity on one side ofthe equation as 0.4x + x instead of 1.4x.
  21. Oct 21, 2010 #20
    tiny-tim
    Hi I Like Pi!! :smile:
    (since you like them so much, have a pi: π :wink:)
    Yes, and now use cosθ = sin(π/2 - θ) to get that in the form sinA = sinB. :smile:
Similar Discussions: Hard thinking questions
  1. Hard trig question (Replies: 12)
Loading...
