1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Hardest work problem
  1. Feb 25, 2014 #1
    A bucket of water with mass 100kg is on the ground attached to one end of a cable with mass per unit length of 5kg/m. The other end of the cable is attached to a windlass 100m above the bucket. if the bucket is raised at a constant speed, water runs out through a hole in the bottom at a constant rate to the extent that the bucket would have mass 80kg when it reaches the top. To further complicate matters, a pigeon of mass 2kg lands on the bucket when it is 50m above the ground. He immediately begins taking a bath, splashing water over the side of the bucket at the rate of 1kg/m. Find the work done by the windlass in raising the bucket 100m.
    2. Relevant equations
    3. The attempt at a solution
    No idea, Can someone help me solve this?
  3. Feb 25, 2014 #2
    Ah here is an attempt.
  4. Feb 25, 2014 #3
    Ray Vickson
    You are dealing with a variable-mass problem. See, eg., http://en.wikipedia.org/wiki/Variable-mass_system or
    or http://vixra.org/pdf/1309.0210v1.pdf . These can be quite tricky.
  5. Feb 26, 2014 #4
    I looked at those links and I think you may be overcomplicating the problem. For the parts that are decreasing I found out that I have to take the initial weight minus the rate of decrease multiplied by the length (y). So (100kg-0.2kg/m(ym))dy. I get the correct order of magnitude but the answer is slightly off.
  6. Feb 26, 2014 #5
    This problem is a type where you can solve by evaluating the definite integral.
  7. Feb 26, 2014 #6
    I don't seem to be able to match those integrals up with the various components, perhaps because some are erroneous.
    Please separate out and identify each of the work components and state the integral for each.
Have something to add?
Draft saved Draft deleted
Similar Threads - Hardest problem Date
Hardest integral ever Apr 7, 2013
Hardest logic problem! Nov 13, 2012
My professor picks the hardest problems Jul 6, 2010
The hardest ever Apr 11, 2009
Possibly the hardest limit question i have ever come across. Oct 6, 2008
