Harmonic oscillator problem
And once you do that, you can find the normalization condition and mean value for the energies in terms of c0 and c1. If you assume <H>= hω, you can solve for c0 and c1.
EEnerd
consider a harmonic oscillator of mass m and angular frequency ω, at time t=0 the state if this oscillator is given by
|ψ(0)>=c1|Y0> + c2|Y1> where |Y1> , |Y2> states are the ground state and the first state respectively
find the normalization condition for |ψ(0)> and the mean value for the energies <H> in terms of C0 and C1, (b)and if we assume <H>= hω calculate c0 and c1
ok i know that |c0|^2 +|c1|^2 =1
and <ψ|H|ψ>= E0|c0|^2 + E1|c1|^2 where E0=1/2 ωh and E1= 3/2 ωh
Well, keep going. You've got two equations in the two unknowns |c0|^2 and |c1|^2. You won't be able to determine c0 and c1 but you can find their absolute values.
1. What is a harmonic oscillator?
A harmonic oscillator is a system that exhibits periodic motion around an equilibrium point, with a restoring force that is directly proportional to the displacement from the equilibrium point. Examples of harmonic oscillators include a mass attached to a spring and a pendulum.
2. What is the harmonic oscillator problem?
The harmonic oscillator problem is a classical physics problem that involves finding the equation of motion for a harmonic oscillator and determining its behavior over time. This problem is commonly used to model various physical systems in fields such as mechanics, electromagnetics, and quantum mechanics.
3. How do you solve the harmonic oscillator problem?
The harmonic oscillator problem can be solved using various mathematical techniques, such as differential equations, Taylor series, and Fourier transforms. The specific method used depends on the type of harmonic oscillator and the desired level of accuracy in the solution.
4. What are the applications of the harmonic oscillator problem?
The harmonic oscillator problem has various applications in physics and engineering, including modeling the motion of atoms and molecules, analyzing the behavior of mechanical and electrical systems, and studying the properties of waves. It is also used in fields such as signal processing, robotics, and quantum computing.
5. What are some real-life examples of harmonic oscillators?
There are many real-life examples of harmonic oscillators, including a guitar string, a swing, a tuning fork, and a quartz crystal in a watch. These systems all exhibit periodic motion around an equilibrium point and can be described using the harmonic oscillator problem.
