Harmonic oscillator
  • Thread starter quas
a mass is placed on a loose spring and connected to the ceiling. the spring is connected to the floor in t=0 the wire is cut
a. find the equation of the motion
b. solve the equation under the initial conditions due to the question
## \sum F=ma
## x(t)=Asin(\omega t + \phi ) ##
a. due to the 2 law of newton: ## \sum F=ma_x
## mg-kx=ma ##
mg-kx=m\ddot{x}
\ddot{x}=g-\frac{k}{m}x ##
b. first I'll find the point equilibrium
c-kx=ma
c-kx=m\cdot 0
x_0=\frac{c}{k}
then I'll define ## y=x-x_0 ##
How do I go from here?
thanks
Answers and Replies
TSny
3,455
##\ddot{x}=g-\frac{k}{m}x ##
OK
##x_0=\frac{c}{k}##
What does c stand for?
Rewrite the differential equation in terms of y instead of x.
418
As TSny hints, you tripped finding x0. Think again what condition will be true at equilibrium and define x0 again. There won't be an unknown c.
OK
sorry I meant ## x_0 = \frac{mg}{k}##
ok and then ## \ddot{y}=g-\frac{k}{m}y ## ?
BvU
14,448
3,737
\ddot{y}=g-\frac{k}{m}y## can't be right. Compare with ##
\ddot{x}=g-\frac{k}{m}x##
I might have a barrier but I do not understand how to build a differential equation for y,,,,
I understand that ## \dot{x}=\frac{dx}{dt}=\frac{dy}{dt}=\dot{y} \\ a=\ddot{x}=\frac{d^2x}{dt^2}=\frac{d^2y}{dt^2}=\ddot{y} ##
418
??? I must be thick this morning, but if positive y is down that looks ok to me.
418
Oh, good grief. It took me a minute!!
418
Much later after it stops oscillating and y is y0 what is the acceleration? g?
BvU
14,448
3,737
Simple: the second derivatives on the left are equal alright. But you need to substitute your expression for y in terms of x. Not just y = x, but: ...:rolleyes:
Related Threads on Harmonic oscillator
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
