Harmonic Waves and Overtones
In summary, a 2.00m long rope is stretched between two supports with a tension that makes the speed of transverse waves 48.0m/s. The wavelength of the second overtone is 2.00m.
rwsunny85
A 2.00m long rope is stretched between two supports with a tension that makes the speed of transverse waves 48.0m/s .
What are the wavelength of the second overtone?
L=nλ/2
I got 2.00 m. Since L=2.00m and n=2 being the 2nd overtone. The site counted it wrong.
Edit: Also I did the same problem but with the 4th overtone using that equation and got it correct.
Never mind! Professor made a mistake. He meant 3rd harmonic. Way to waste 30 minutes of my life.
For a string the second overtone is the third harmonic
Really? How does that work?
It's just a different way to name things.
Fundamental frequency = first harmonic
First overtone = second harmonic
Second overtone = third harmonic
etc.
The harmonics are defined as the sequence of frequencies obtained by multiplying the fundamental frequency by whole numbers. So if the fundamental frequency is f, the harmonics are given by fn = nf and the first harmonic (n=1) coincides with the fundamental. The overtones on the other hand are defined as the sequence of frequencies above the fundamental - literally overtone means above the tone and the tonic is just another name for the fundamental (in that context).
For a string instrument, the overtones coincide with the harmonic series so we have, as AlephZero explained the identification.
etc.
That's also the case for open wind instruments such as a flute. But closed wind instruments (blowing off the top of a beer bottle for instance) only produce odd harmonics so we have a different identification table
First overtone = third harmonic
Second overtone = fith harmonic
etc.
The overtones produced by percussion instruments are in general much more complex and in general do not coincide with the harmonic series at all.
That's why drums are - well - less harmonic in nature and are not used to create harmony (musical cords). For instance in a piano (string instrument) if you play a tonic, a major third and a fifth at the same time, you create a nice sounding chord called the major cord. That works because the 2nd overtone of the tonic coincides with the 1st overtone of the fifth and the 4th overtone of the tonic coincides with the 3rd overtone of the major third, and the 4th overtone of the fifth coincides with the 5th overtone of the major third. All these matching overtones bind the different notes into a harmonic chord. Since a drum's overtones are not harmonic, trying to play chords with drums doesn't really work. The overtones don't match and the chord wanna-be just sounds like a muddled mess. Drums are for rhythm - not harmony.
What are harmonic waves?
Harmonic waves are a type of periodic wave that repeats itself at regular intervals. They are characterized by having a single frequency and wavelength, and are commonly found in music and sound waves.
What are overtones?
Overtones are additional frequencies that are produced along with the fundamental frequency of a harmonic wave. They are created by the natural vibrations of an object and are responsible for the unique sound quality of different instruments and voices.
How do harmonic waves and overtones relate to each other?
Harmonic waves and overtones are closely related, as overtones are essentially multiples of the fundamental frequency of a harmonic wave. They are present in all types of harmonic waves, including sound waves, electromagnetic waves, and water waves.
What is the difference between harmonic waves and non-harmonic waves?
The main difference between harmonic and non-harmonic waves is that harmonic waves have a single frequency and wavelength, while non-harmonic waves have multiple frequencies and wavelengths. This gives harmonic waves a regular and repeating pattern, while non-harmonic waves have a more complex and irregular pattern.
How are harmonic waves and overtones used in everyday life?
Harmonic waves and overtones have many practical applications in everyday life. They are used in music and sound production, as well as in communication technologies such as radios and telephones. They also play a role in medical imaging and industrial processes such as ultrasound and sonar.
17K
