Homework Help: Have i done this right?
  1. Dec 5, 2008 #1
    Needing to factor the relevent equation.
    2. Relevant equations
    (pM)= ½ (F²vt/c)+ ½ (F²vt/v)
    Square both sides:
    (pM)²= ½ (F²vt/c)² + ½ (F²vt/v)²
    3. The attempt at a solution
    Square both sides:
    Then factor and simplify
    ½ F²(vt/c – vt/v)= p²M²
  3. Dec 5, 2008 #2
    If I square both sides of [tex]y = \frac{1}{2}x[/tex], I don't get [tex]y^2 = \frac{1}{2}x^2[/tex] ... I get [tex]y^2 = \frac{1}{4}x^2[/tex].
    If I square both sides of [tex]y = a + b[/tex], I don't get [tex]y^2 = a^2 + b^2[/tex] ... I get [tex]y^2 = (a+b)^2 = a^2 + 2ab + b^2[/tex].
  4. Dec 5, 2008 #3
    And might I also suggest that factoring a bit earlier might simplify the problem.
  5. Dec 5, 2008 #4
    In other words i have squared wrongly... which i have... hold on, because one i properly do this, i still need to factor it out correctly.
  6. Dec 5, 2008 #5
    How would i do that exactly?
    Thanks by the way.
    I ask because i am bit confused about my operations.
  7. Dec 5, 2008 #6
    Well, if I had an equation of the form [tex]y = abx - abt[/tex], and wanted to solve for x, I might want to consolidate the common factors first:
    [tex]y = ab (x - t)[/tex]
    Then move them over to the other side by dividing through by those common factors:
    [tex]\frac{y}{ab} = x - t[/tex]
    Hmm. Only one step remains, and it can be done by adding an element to both sides.
  8. Dec 5, 2008 #7
    But concerning my equations... Is this relevent, because i am a terrible problem solver
  9. Dec 5, 2008 #8
    What do these fellows have in common?
    And I hate to ask this late in the game, but what are we solving for, here? Do we stop at factoring, or go on to solve for c or v? Because the step above is as good a run at factoring as you're likely to get. The rest is algebra (adding, subtracting, multiplying, dividing, etc through the entire equation).
  10. Dec 5, 2008 #9
    We are factoring out the F. And we also solve for F... if that makes sense? If it doesn't, then perhaps i need to solve for v or c?
  11. Dec 5, 2008 #10
    Yep, F's easy. But try to figure out the problem yourself first. Hint:
    If
    [tex]f = \frac{abx}{c} + \frac{abx}{x}[/tex]
    then
    [tex]f = abx(\frac{1}{c} - \frac{1}{x})[/tex]
    or equivalently (if we leave the x behind)
    [tex]f = ab(\frac{x}{c} - 1)[/tex]
  12. Dec 5, 2008 #11
    Right, o'k. I can work that out. Hold on. Cheers.
  13. Dec 5, 2008 #12
    pM=Fvt/c+Fvt/v
    pM=Fv(t/c– 1)
    Is the only pattern I see in this. Is this formula supposed to help, because I am really confused. This is the second time I have came here, funnily enough to be such confused again. But if ya could help, I’d appreciate a more direct response, because I am absolutely no good at mathematical riddles, or anything for me to solve. I don’t have a mathematical brain really ;)
  14. Dec 5, 2008 #13
    Well, they're not really riddles. See, I could show you a gun and shoot a duck. Then I could hand you a gun and ask you to shoot a crow. The wrong answer in that case would be "But you didn't show me how to shoot a crow, just a duck."
    Teaching by way of example is a time honored tradition. If I say I can solve y = 5x for x by dividing through by 5, I get y/5 = x. Ta daah.
    But what about y = 6x? Same trick. y/6 = x
    But what about y = kx, where k is some constant? Same trick. y/k = x. Ta daah.
    What about a whole conga line of constants? If y = abcdefgx, hey, I can pick em off 1 by 1 like . . . well, like shooting ducks . . . and get y/(abcdefg) = x
    Sometimes we answer in examples. Not riddles.
    Past that? It's homework help, not solutions. I could hand over an answer, and you could repeat it, but . . .
    there will be more ducks.
    Anyways, your factorization left out a number of things. Try this on and see if you can work it from here. Better yet, try to figure out how I came up with this.
    Given:
    The factors can be combined to this just-about-ready-to-solve-for-F type form:
    [tex]
    2 p M = F^2 t ( \frac{v}{c} - 1 )
    [/tex]
  15. Dec 5, 2008 #14
    Simple algebraic rules otherwise, like
    E=Mc^2
    M=E/C^2
    C^2=E/M
    I know this. This is not what i was asking in the first place. But, you say the last part, and i suppose this is the proper way to factor this out for F?
  16. Dec 5, 2008 #15
    Good response, now apply it and solve for F^2 as you have solved for C^2 in your example.
  17. Dec 5, 2008 #16
    And you can check to see if it's a proper factorization by multiplying it out, reversing the procedure.
