Homework Help: Having issues with units
  1. Oct 27, 2012 #1
    ISX
    Venturi effect nozzle.. Starts off at 100cm and goes down to 40cm. The flow rate of the gas is 2.23 m3/s. What is the average velocity at the beginning and end of the nozzle.
    2. Relevant equations
    Continuity Formula, Bernelli = Q = A1V1=A2V2
    3. The attempt at a solution
    It's not the solution I am having trouble with so much, I am having a brain fart with units. I can take the area of 100cm and get 7850 cm2 and 40cm works out to 1256cm2 and you end up with a starting velocity of 0.000284 and an ending velocity of 0.001775 which I am assuming is cm/s.. Is that right or do I need to convert 100cm and 40cm to meters first and then do the calculation and then end up with meters/s?
  3. Oct 27, 2012 #2
    TSny
    2017 Award
    Hi ISX. No need to assume anything here. If you carry your units along in the calculation it will guide you. You have V = Q/A. You plugged in numbers as V = (2.23 m3/s)/(7850 cm2). So, what do the units reduce to here?
  4. Oct 27, 2012 #3
    ISX
    I guess I've never read it like you put it, just always had a guide to follow in the book. I see cubic meters and cm squared so I woulda thought you would make them both cm or both meters..so I'm still not sure.
  5. Oct 27, 2012 #4
    TSny
    2017 Award
    Right. You can go either way: convert the cm2 to m2 or convert the m3 to cm3.
  6. Oct 27, 2012 #5
    ISX
    Alright so both of these should be right then.
  7. Oct 27, 2012 #6
    TSny
    2017 Award
    Yes. Nice. :smile:
  8. Oct 27, 2012 #7
    ISX
    Schweeeeet. Thanks.
