Having trouble on trig question
  • Thread starter david18
Hi, I get stuck on the 3rd part of this question:
(i) Draw sketches of the functions sin x and [itex]sin^2x[/itex] over the range -360<x<360.
(ii) Explain why, for the range 0 < x < 90=2, sin x is smaller than tan x.
(iii) Using the equality [itex]cos^2x=\frac{1}{2}(1+cos2x)[/itex] or otherwise, express
[itex]cos^4x[/itex]in terms of cos2x and cos4x.
My attempt at part iii:
I squared the left hand side of [itex]cos^2x=\frac{1}{2}(1+cos2x)[/itex] to get [itex]cos^4x[/itex] and therefore squared the right hand side as well, leaving the right hand side as [itex]\frac{1}{4}(1+cos2x)^2[/itex]
I'm presuming I have to square the right hand bracket out but I'm unsure on what (cos2x)^2 becomes.
Any help would be appreciated
Answers and Replies
HallsofIvy
41,833
961
If you know (because it was just given!) that
[tex]cos^2(a)= \frac{1}{2}(1+ cos(2a)[/tex]
for any a, then what is [itex]cos^2(2x)[/itex]?
Thanks for the reply, following your method I ended up with [itex]\frac{3}{8}+\frac{1}{2}cos2x+\frac{1}{4}cos4x[/itex]
Just out of interest, if I were to square cos2x would I have to use the knowledge given in the question or does it equal something obvious?
HallsofIvy
41,833
961
Only the "obvious" [itex]cos^4(2x)[/itex]! But then you could use the same identities to reduce that. It's just easier to use the already factored form.
Related Threads on Having trouble on trig question
  • Last Post
  • Last Post
