HCl Dissolving in Water: Calculating pH and Titration with NaOH
  • Thread starter chawki
  • Tags
    Hcl
In summary, HCl gas dissolves in water to form hydrochloric acid, which dissociates fully into ions (H+ and Cl-). To calculate the pH of a solution made by dissolving 1.6 grams of HCl in 0.40 liters of water at 298 K, the molar concentration of H3O+ is determined to be 0.11 mol/l. Using the equation pH = -log [H3O+], the pH is found to be approximately 0.96. In a titration between 0.050 mol/l NaOH and 0.10 mol/l HCl, using the equation Ca*Va = Cb*Vb, it is calculated that 60
chawki
506
HCl gas dissolves in water consisting of hydrochloric acid, or hydrochloric acid. HCl dissociates
fully ions as follows: HCl → H+ + Cl-.
a) Calculate the pH of the solution, which is made ​​by dissolving 1.6 grams of HCl in 0.40 liters of water 298 K temperature.
b) How many ml it takes 0.050 mol/l NaOH solution, when it titraat 30 ml of 0.10 mol/l HCl solution?
a)
molar cencentration of H3O+ = n/V
n= 0.0438 mol
C= n/V = 0.0438/0.4 = 0.11 mol/l
PH = -log C of H3O+
PH = -log 0.11
PH = 0.96 (approximately)
b)
HCl with NaOH
Ca*Va = Cb*Vb -------------- we search V of NaOH
Vb = (Ca*Va)/Cb
Vb = (0.10*0.03)/0.050
Vb = 0.06 L
that's 60ml
Looks OK.
chawki said:
HCl with NaOH
Ca*Va = Cb*Vb
Beware - you are omitting stoichiometric coefficients. They equal 1 in this case, so the equation holds, but it doesn't hold automatically for every titration.
Borek said:
Looks OK.
Thank you Borek :smile:
but how would it be if we had 2HCl and 1 NaOH
2 Ca*Va = Cb*Vb ?
also i wonder why they gave us the 298K
2 Ca*Va = Cb*Vb ?
That's not how they react. See
http://www.titrations.info/titration-calculation
My guess is they gave it to make you wonder...
I would like to provide some feedback on your attempt at solving these problems. Your calculations for the pH and titration are correct, but it would be beneficial to include more explanation and context for these calculations. For example, you could explain the significance of calculating pH and how it relates to the dissociation of HCl in water. Additionally, you could explain the purpose of titration and how it is used to determine the concentration of a solution. Including these details would not only make your response more informative, but also help the reader understand the concepts better.
What is HCl and why does it dissolve?
HCl, or hydrochloric acid, is a strong acid commonly used in laboratory and industrial settings. It is a corrosive substance that can dissolve many materials due to its highly reactive nature. When HCl is added to water, it dissociates into hydrogen ions (H+) and chloride ions (Cl-), which are responsible for its ability to dissolve other substances.
What substances does HCl dissolve?
HCl can dissolve a variety of substances, including metals, salts, and other acids. Some common examples include iron, zinc, magnesium, and sodium chloride (table salt). It can also dissolve certain organic compounds, such as proteins and carbohydrates.
How does HCl dissolve substances?
HCl dissolves substances through a process called acid-base neutralization. The hydrogen ions (H+) in HCl react with the other substance's ions or molecules, breaking them apart and forming new compounds. This process continues until all of the substance is dissolved or until a chemical equilibrium is reached.
Why is HCl commonly used for dissolving substances in experiments?
HCl is commonly used in experiments because of its strong acidic properties and its ability to dissolve a wide range of substances. It is also readily available and relatively inexpensive. In addition, its concentration can be easily adjusted, making it a versatile chemical for various experiments.
Is HCl safe to use for dissolving substances?
While HCl is commonly used in laboratory settings, it is a corrosive substance and can be dangerous if not handled properly. It is important to follow safety precautions, such as wearing protective equipment and working in a well-ventilated area, when using HCl. Additionally, proper disposal methods should be followed to avoid harm to the environment.
