Headphone Impedance
  • Thread starter raymil
raymil
Hello
I am a newbie in all this stuff, so I would appreciate any help on this. I have come to posses an old amplifier, a Victor JA-S11 Stereo Integrated Amplifier, it is working very well and excellent sound quality. It has Headphone output jack. Currently I don't have any speakers to use it, and I thought about using an old headphone, it is a LLoyd's Stereo Headphones MODEL Y691.
My question is, can I use this headphone with this amplifier without causing damage to the amplifier or the headphones? Also, how can I determine the headphones impedance?
I have tried to find this information on the web, but since these are very old equipment I couldn't find anything about neither of these two.
Thanks a lot!
Answers and Replies
berkeman
Mentor
63,240
14,194
Headphones won't hurt your amp. Don't worry about their input impedance.
When you start pushing several 100s of watts into the load from the main outputs of your amp, then the Zin of the speakers will be important.
raymil
I think I will try then. Thanks a lot. :-)
berkeman
Mentor
63,240
14,194
Actually, I should clarify my statement a bit. As long as you plug your headphones into the headphone jack, they won't hurt your amp. If you connect them to the output of the amp and turn up the volume, you'll blow the headphones obviously, and maybe hurt the output stage of the amp. At high output power levels, audio power amps generally need to have their rated load/speaker impedance connected. If you turn up the "volume" with no speakers attached, you can hurt the output stage of the amp with an overvoltage condition (if the amp wasn't designed to run safely without speakers connected).
Suggested for: Headphone Impedance
