Heat absorbance: PLS PLS HELP
  • Thread starter sun
sun
39
Heat absorbance: PLS PLS HELP ASAP!!
A quantity of a monatomic ideal gas undergoes a process in which its pressure is increased by a factor of n = 3 and its volume is increased by a factor of m = 6 as shown in Figure P12.12. What is the heat absorbed by the gas during this process? (Hint: See Problem 1. Answer in terms of P0V0.)
http://www.webassign.net/sercp/p12-12alt.gif
this is what i've done so far, but i keep getting it incorrect.
work (W), which equals -1/2 (n*Po-Po)(m*Vo-Vo) - Po(Vo-Vo)
delta U = (3/2) [(m*Po)(n*Vo) - PoVo]
delta U=(3/2)[(6Po)(3Vo)-PoVo]=(3/2)(17PoVo)
W=(-1/2)((3Po-Po)(6Vo-Vo)-Po(Vo-Vo))=(-1/2)((2Po)(5Vo)-(Po(Vo-Vo))=-5PoVo
U=Q+W
I solved for W and got 30.5xPoVo.
I'm clearly doing some incorrect algebra somewhere. Could i please get some help?
thanks
Answers and Replies
dynamicsolo
1,648
work (W), which equals -1/2 (n*Po-Po)(m*Vo-Vo) - Po(m*Vo-Vo)
Since the process path is a straight line, the work on the gas is just the negative of the area of the trapezoid under the line, which is what you have. (I corrected your second term.) If you put in the values for m and n, you get -10PoVo.
We'll call the number of moles C for the moment (it cancels out). So To = PoVo/CR and T' = 18PoVo/CR , so
delta U = (3/2)·C·R· (17PoVo/CR) = (51/2)PoVo = 25.5PoVo
deltaU=Q+W
so Q = deltaU - W = 25.5PoVo - (-10PoVo) = 35.5PoVo .
It's that second term in your work equation: you dropped the factor n in the volume difference.
Related Threads on Heat absorbance: PLS PLS HELP
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
