Heat air, water and generate electricity from solar tubes.
In summary: Based on the information provided, the most efficient way to generate electricity from your solar thermal system would be with a Thermionic Electrical Generator. These generators use the "Seebeck effect" to convert energy from heat into electricity. They range in output from 76 watts up to 2,000 watts, making them perfect for small systems like yours.
taylaron
Greetings PFers
I’m thinking about building a Tiny House similar to the one below, except outfitted with solar power.
http://www.tumbleweedhouses.com/products/weebee/#ad-image-0
A Tiny house is a small (~120 sqft) home on a trailer bed. I’m interested in designing one that is equipped with a solar water and air heater as well as power generator. Because solar thermal is not a complete solution to heating air, water or generating power, it should be able to be switched
based on demand. The solar water heater would simply supplement the on-demand propane heaters.
I’m thinking about using an array of Solar Tubes (Glass evacuated thermal collectors) on the roof
https://www.amazon.com/dp/B00ANL3OHC/?tag=pfamazon01-20
At the end of each tube is a brass cylinder where the heat is transferred. The question is what method is most efficient and practical for transferring heat to electricity to charge a battery in this application.
I’m not using Photovoltaics because they’re so expensive right now and it’s not worth the investment with more efficient panels coming out in the near future.
Conversion options that I see:
1. 12volt Peltier device (10-15% efficiency. Requires temp. differential). Direct conversion.
2. Sterling Engine connected to a 12 volt PM DC generator
a. 25% efficient Stirling * 75% DC generator = 19% overall efficiency
With these rough calculations, it looks like ~80-90% of the energy collected by the solar thermal tubes will be lost regardless of generation method. In the interest of simplicity, I would go with the Peltier device option to generate electricity.
To produce hot air or water, the oil which would circulate through the system would pass through a refrigerator radiator which has two tubes, one originally for coolant and one for cooling water going to the spigot. The hot oil and soon-to-be hot water would pass through the two tubes in the radiator and the water would go into an insulated container for later use while the oil is recycled.
Hot air would be produced by stopping the flow of water through the radiator and passing air through the radiator fins.
I also envision each solar tube having it's own parabolic dish along it's length if it would fit in the roof. The top of the solar collector would be covered in corrugated plastic to prevent glare off the roof.
If I've missed an alternative or have any corrections, I would appreciate your input.
-Tay
Hi taylaron! You've been absent!
As for your project, I like the Winston Compound Parabolic Collector:
"The students were led by Professor Roland Winston, and their system uses what are known as External Compound Parabolic Concentrators (XCPCs). Each device concentrates sunlight onto a specially-designed collector tube, which converts that sunlight's energy into heat. The combined solar heat from an array of these XCPCs can be fed into a building's heating system, used to generate electricity, or to run an absorption chiller-style air conditioner - these generate cold air in a process that utilizes heat, as opposed to electricity created from heat."
http://www.gizmag.com/solar-collector-runs-air-conditioner/20029/
Hey Bobbywhy, nice to hear from you.
Winston's compound parabolic collector sounds very similar to my own, except his team designed it to cool air. I'm interested in being able to switch from heat to cool if practical. Convection driven air conditioners instead of pump driven air conditions are less efficient, but the fact they use heat as a source of energy cannot be ignored.
I'm curious what system they used to absorb the solar radiation and what they used as reflective material. 3M's solar reflector film is very* Expensive.
After staring at the picture, it looks like they simply made their own solar tubes. Instead of being cylindrical, they used a triangular form factor. Wither or not they're in a vacuum or simply surrounded by Xenon or something, i don't know. I cannot find any more information on their construction unfortunately.
Bobbywhy, what method do you think I should use to generate electricity?
-Tay
My preference for generating electricity is one with no moving parts: Thermionic Electrical Generators using the "Seebeck effect".
Here are a few sources of units for sale, with outputs as high as 76 watts!
Small Thermoelectric Generators
http://www.electrochem.org/dl/interface/fal/fal08/fal08_p54-56.pdf
http://thermoelectric-generator.com/
https://theepicenter.com/cgi/order.cgi/s?page=power_sources_generators_and_batteries.html&cart_id=%%CArt_id%%
http://thermoelectric.alignsourcing.com/category/thermoelectric-generators-and-assemblies-teg-
Hi Tay,
Thank you for sharing your plans for a Tiny House with solar power capabilities. It's great to see individuals thinking about sustainable and efficient ways to power their homes.
Your idea of using solar tubes to heat air and water and generate electricity is definitely feasible. However, as you mentioned, there are some efficiency and practicality considerations that need to be taken into account.
In terms of generating electricity, your options of using a Peltier device or a Sterling engine are both viable. However, as you also noted, there will be a significant loss of energy during the conversion process. One alternative you may want to consider is using a solar thermal power system, which uses mirrors to concentrate sunlight onto a receiver to heat a fluid, which then drives a turbine to generate electricity. This may be a more efficient option for generating electricity from solar thermal energy.
For heating air and water, your idea of using a refrigerator radiator is a creative solution. However, it may not be the most efficient way to transfer heat. Another option could be to use a heat exchanger, which would allow for more efficient transfer of heat between the oil and the air or water. Additionally, incorporating some form of storage for the heated air and water would allow for more flexibility and efficiency in using the energy collected by the solar tubes.
Overall, I think your plans are well thought out and it's great to see your enthusiasm for incorporating renewable energy into your Tiny House. Keep exploring different options and technologies, and I'm sure you will find the most efficient and practical solution for your needs. Best of luck with your project!
Sincerely,
1. What is the process of generating electricity from solar tubes?
The process of generating electricity from solar tubes involves using a series of photovoltaic cells within the tubes to convert sunlight into electricity. The cells are made of silicon, which absorbs the sunlight and releases electrons, creating a flow of electricity.
2. How does heat air and water at the same time using solar tubes?
Solar tubes can be designed to have a dual purpose of generating electricity and heating air and water. This is achieved by using a heat exchanger, which transfers the heat from the tubes to a fluid, such as water. The heated fluid can then be used for various purposes, such as heating a home or providing hot water.
3. What are the benefits of using solar tubes for generating electricity?
There are several benefits to using solar tubes for generating electricity. They are a renewable energy source, meaning they do not deplete natural resources. They also produce no emissions, making them environmentally friendly. Additionally, solar tubes have a long lifespan and require minimal maintenance, making them a cost-effective option in the long run.
4. Can solar tubes still generate electricity on cloudy days?
Solar tubes can still generate electricity on cloudy days, although the amount of electricity produced will be less compared to a sunny day. The photovoltaic cells can still convert diffuse sunlight into electricity, but the efficiency may be lower. However, using a battery storage system can help to store excess electricity generated on sunny days for use on cloudy days.
5. Are there any drawbacks to using solar tubes for electricity generation?
One potential drawback of using solar tubes for electricity generation is the initial cost of installation. However, this cost can be offset by long-term savings on energy bills. Another drawback is that solar tubes can only generate electricity during daylight hours, so alternative sources of electricity would need to be used at night. Additionally, the efficiency of solar tubes can vary depending on location and weather conditions.
  • General Engineering
  • Mechanical Engineering
