Solve Heat Capacity Question: 12kg Water, 15.4°C to 93°C
In summary, the formula for calculating heat capacity is Q = m x c x ∆T, where Q is the amount of heat absorbed or released, m is the mass of the substance, c is the specific heat capacity, and ∆T is the change in temperature. The mass of water in a heat capacity question is typically given or can be measured using a balance, and in this case, the mass of water is 12kg. The specific heat capacity of water is 4.186 joules per gram per degree Celsius (J/g°C), meaning it takes 4.186 joules of energy to raise the temperature of 1 gram of water by 1 degree Celsius. To convert Celsius to Kelvin, you add
geffman1
67
hey guys I've got a question.
'calculate the amount of heat necessary to raise the temperture of 12kg of water from 15.4degrees to 93 degrees.
My working= h=mCdelatT
m=12000
C?
Delta T=77.6K
just wondering how i find C? (heat capacity)
thansk for any help
Tables.
To find the heat capacity (C) of water, we can use the formula C = Q/mΔT, where Q is the amount of heat needed, m is the mass of the water, and ΔT is the change in temperature. In this case, we know that the mass (m) is 12kg and ΔT is 77.6K. We also know that the specific heat capacity of water is 4.186 J/gK. Therefore, we can calculate the heat capacity of water as follows:
C = Q/mΔT
C = (12000g)(4.186 J/gK)(77.6K)
C = 37,999,872 J/K
Therefore, the amount of heat necessary to raise the temperature of 12kg of water from 15.4°C to 93°C is approximately 37,999,872 Joules.
What is the formula for calculating heat capacity?
The formula for calculating heat capacity is: Q = m x c x ∆T, where Q is the amount of heat absorbed or released, m is the mass of the substance, c is the specific heat capacity, and ∆T is the change in temperature.
How do you determine the mass of water in a heat capacity question?
In a heat capacity question, the mass of water is typically given or can be measured using a balance. In this case, the mass of water is 12kg.
What is the specific heat capacity of water?
The specific heat capacity of water is 4.186 joules per gram per degree Celsius (J/g°C). This means that it takes 4.186 joules of energy to raise the temperature of 1 gram of water by 1 degree Celsius.
How do you convert Celsius to Kelvin?
To convert Celsius to Kelvin, you add 273.15 to the Celsius temperature. In this question, the initial temperature of 15.4°C would be converted to 288.55K.
What is the final temperature of the water in this heat capacity question?
The final temperature of the water can be calculated by rearranging the heat capacity formula, Q = m x c x ∆T, to solve for ∆T. In this case, ∆T = Q / (m x c) = (93°C - 15.4°C) = 77.6°C. Therefore, the final temperature of the water is 93°C.
  • Thermodynamics
9K
15K
