Comparing Specific Heat Capacity of Metals A & B in Wax Block
In summary, the metal ball with a higher specific heat capacity (B) will sink deeper in the wax block due to its ability to release more energy over a longer period of time compared to the other metal ball (A). This is because the higher specific heat capacity means that it requires more energy to change its temperature, allowing it to stay warm for longer and continue melting the wax. Additionally, the specific heat capacity equation (E=mcΔt) can be used to confirm that the ball with higher specific heat capacity will have a greater energy transfer compared to the other ball.
HemaZ
Metal B has double the specific heat capacity of metal A. Both metals have almost the same density. Two small spheres that have the same radius of A and B are heated in an oil bath till 400oC, then they are removed at the same time and placed above the surface of a wax block with 20 cm separation. Which sphere goes deeper inside the wax?
a) Both go to the same depth, since they have the same starting temperature.
b) A goes deeper than B.
c) B goes deeper than A.
d) I must know the specific heat capacity of wax to tell the difference
the answer is c) but i can't figure why ! is the more heat capacity substance lose and gain energy faster than the other one so it take more energy to get it's temperature raised by the same amount because it lose most of it very fast during the heating process ?
It takes energy to melt wax. How much energy does each ball contain?
i think Metal B will contain the double of Metal A
And therefore ...
So B can melt more wax than A.
I had fun imagining both balls being "placed above the surface of a wax block" at considerable height and on e.g. a shelf. For the sake of seriousness I suppose they mean "placed on the surface of a wax block" :smile:
Also liked the realistic touch added by mentioning the 20 cm separation...
I assume you mean double the energy rather than double the metal.
yes sir
Do not think. Use the specific heat capacity equation and confirm it.
##E=mc\Delta t## -##t## is temperature.
i know that the metal B contain double energy of metal A but the energy transfer in the same time period to the wax is the double too ?!
Of course. Why not?
If we assume the temperature difference between the metal and the wax is same. Then that's it.
does this mean the substance with higher heat capcity transfer heat faster ?
This would depend both on the specific heat capacity and the thermal conductivity of the substance. The specific heat tells you how much energy you need to put into (or take away from) the material to change its temperature. The thermal conductivity tells you how large the energy flow is relative to the temperature gradient.
Given the same thermal conductivity and transfer conditions on the surface, the material with the higher specific heat capacity would cool down slower, meaning it would initially melt wax at more or less the same rate. However, it would stay warm for longer and therefore keep on melting wax and go deeper in the end. For different thermal conductivities, the time-scale of the process may be different, but the total energy release from the material to end up below the wax melting point will stay the same.
Why bother about faster if the exercise asks for a distance ? They sink in and they stop at some point. Don't have to stop at the same moment !
Why stop at what the exercise asks you for if you find other aspects of the problem interesting or wonder about related things? I would recommend to rather encourage such things.
@druin: there may be more exercises waiting. Hopefully with more concrete input. Thermal conductivity of most metals is a lot higher than that of wax, so a temperature gradiënt in the metal balls is pretty small anyway.
Really nice explanation .
Do you mean that both A and B will have to reach the temperature of wax i.e change in temperature would be same (Δt is equal) and since specific heat of B is more than that of A ,using Q=msΔt,heat transfer will be more for B ?
@Vib: more or less. The initial 400 degrees is pretty hefty.
I don't plan to do the experiment, but I can fantasize a little bit:
first choose my balls, e.g.
Indium, cp 0.24 kJ/(kg.K) , rho 7310 kg/m3 and
Steel with cp 0.49 kJ/(kg.K), rho 7850 kg/m3 ), then my target:
Paraffin, cp some 2.5 kJ/(kg.K), rho 900 kg/m3
this wax melts at, say 55 °C, heat of fusion a hefty 200 kJ/kg !
The 20 cm apart from the OP comes in handy for our shopping list:
Let's play safe and buy a lump of wax 60 x 40 x 15 cm3. Just about luggable.
Metal balls ? say 5 cm diameter. If we copy adjacent's formula mcΔt, cooling them from 400 to 55 degrees gives us some 40 and 87 kJ of energy in the form of heat (a ratio of 1:2 if you squint a bit).
For the paraffin, heating up a one-ball volume from 20 to 55 degrees costs only 5.2 kJ, but then also melting it another 11.8 kJ ! together 17 kJ.
The Indium ball can heat up and melt about 2.3 ball volumes and the steel ball 5.1 of them.
So (cylinder / sphere and the last bit is a half sphere) a depth of 1.7 and 3.5 ball diameters is my best guess. Ultimately, after the heat is evenly distributed, the 127 kJ heats up the whole block (mcΔt again) only 1.6 degrees, so there is no risk of a room-size paraffin splotch.
So far, I would bet on the steel ball coming through and the Indium getting stuck a little below half-way.
One thing I would ask your input on: behind the ball, the wax solidifies again, thus releasing 2/3 of the heat going from solid 20 to liquid 55 degrees. A nice fraction of that heat is passed on to the ball, so it may well go a significant factor deeper than I calculated. Who dares to bet the Indium ball makes it through ?
1. What is specific heat capacity?
Specific heat capacity is the amount of heat energy required to raise the temperature of a substance by 1 degree Celsius or Kelvin per unit mass. It is measured in units of J/kg·K.
2. How do you compare specific heat capacity of metals A and B in a wax block?
To compare the specific heat capacity of metals A and B in a wax block, we can conduct an experiment where we measure the temperature change of the wax block when each metal is placed in it. The metal with a larger temperature change will have a lower specific heat capacity.
3. What factors can affect the specific heat capacity of metals?
The specific heat capacity of metals can be affected by factors such as the mass and composition of the metal, the temperature, and any impurities present. Additionally, the state of the metal (solid, liquid, or gas) can also impact its specific heat capacity.
4. Why is it important to compare the specific heat capacity of different metals?
Comparing the specific heat capacity of different metals can provide valuable information for various industries, such as in the design of heating and cooling systems. It can also help in understanding the properties of different metals and their behavior when exposed to heat.
5. How is specific heat capacity useful in everyday life?
Specific heat capacity is useful in everyday life in various ways. For example, it is used in cooking to determine the amount of heat needed to cook different foods. It is also important in understanding how materials respond to changes in temperature, such as in weather forecasting and climate studies.
16K
  • Thermodynamics
