Heat energy required
  1. Mar 11, 2009 #1
    Hi, wonder somone could help me, Im not physics expert. If a lube oil has a specific heat of 0.444Btu/Lb.F, how do I calculate the heat energy (kw) required to raise its temperature from 10C to 40C. Amount of liquid is 35L. Will I be able to calculate the time it takes to raise the temperature as well? someone told me its as easy as using the equation Q=CMΔT but another said I have to use Q=cpdT, Im confused!
  3. Mar 11, 2009 #2
    First i think you should specify wich phisycal quantities hide behind those letters :-),
    in any case The specific heat capacity of a material is:
    c={\partial C \over \partial m}
    In absence of phase transition you have
    c=E_ m={C \over m} = {C \over {\rho V}}
    C is the heat capacity of a body made of the material in question,
    m is the mass of the body,
    V is the volume of the body, and
    [tex]\rho = \frac{m}{V} [/tex] is the density of the material.
    I bet this is the relation in your's formula:
    where C is specific heat capacity at const pressure M the mass of the system and c_p is the body heat capacity at constant pressure.
    I hope this answer can help you, in any case you can check this page:
  4. Mar 11, 2009 #3
    Staff: Mentor
    Use this one:
