Heat engine.
27
A heat engine using 5.00 g of helium gas is initially at STP. The gas goes through the following closed cycle:
- Isothermal compression until the volume is halved.
- Isobaric expansion until the volume is restored to its initial value.
- Isochoric cooling until the pressure is restored to its initial value.
a)How much work does this engine do per cycle?
b)What is its thermal efficiency?
2. Relevant equations
thermal efficiency = Wout/QH
(thermal efficiency)Carnot = 1 - TC/TH
3. The attempt at a solution
for part a) I got:
isothermal work = nRTln(V at 2/V at 1) = -1967 J
isobaric work = p(V at 3 - V at 2) = 2836 J
isochoric work = 0
total work done in one cycle = -1967 + 2836 = 869 J
for pat b) i got:
from 1 to 2:
Q = -W = 1967 J
from 2 to 3:
Q = nC_p(deltaT), C_p for a monatomic gas is (5/2)R, this comes from the equipartition theorem
Q = (1.25)(5R/2)(273K) = 7094 J
from 3 to 1:
Q must be negative since there is a work output so therefore Q in this process is irrelevant since we only need the Q that is added to the system
efficiency = (total work done in one cycle)/(heat added in one cycle)
efficiency = (869 J)/(7094 J + 1967 J) = 0.096=9.6% But apparently thats the wrong answer!
I don't know what's wrong. Help!
alphysicist
2,239
Hi j88k,
for part a) I got:
isochoric work = 0
for pat b) i got:
from 1 to 2:
Q = -W = 1967 J
Looking at this part: If the gas is being compressed and the temperature is not changing, is heat entering or leaving the system? (In the efficiency formula you only count heat going into the system.) Does this help?
27
so the answer would be (869)/(7094)=0.122=12.2% ?
Redbelly98
Staff Emeritus
12,028
112
Looks good! :smile:
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
