1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Heat equation differentiation
  1. Nov 22, 2009 #1
    I'm having trouble deriving the following equation
    [tex] \frac {\partial^2 {\theta}}{\partial {x'^2}} = -y^2*exp(\theta) [/tex]
    and y = x/x'
    my main problem is the exponent
    2. Relevant equations
    3. The attempt at a solution
    Normally i would use the equation
    (x')'' + k^2*x' = 0
    x' = c1 * cos(kx') + c2 * sin (kx')
    can I rearrange the equation as
    [tex] \frac {\partial^2 {\theta}}{\partial {x'^2}} + y*exp(\theta) = 0 [/tex]
    and solve for exp(theta)?
  3. Nov 22, 2009 #2
    lanedance
    what are you trying to derive? do you mean solve the differntial equation
    and what does y = x/x' represent? what is x differentiated w.r.t in the equation to give x' ?
  4. Nov 23, 2009 #3
    ok, so ignore the first post please
    the equation is
    [tex] \frac { d^2 \theta }{d x'^2 } = -y *exp(\theta) [/tex] eq. 1
    first off, this is a steady state model. meaning, we consider the pre-explosion temperature to be small in comparison with the absolute temperature of the walls:[tex] \frac {\Delta T}{T} << 1 [/tex]
    2nd, the reaction rate only depends on the deperature in accordance with exp(-E/RT)
    3rd we regad the thermal conductivity of the walls as being infinitely large.
    x' = x/r is the nondimensionalization of x, r is the half length (i.e radius for cylinder), not the derivative, for -L < x < L we have -1 < x' < 1. x' drops unit (i.e m, cm, ..)
    theta is the nondimensionalization of temperature [tex] \theta = \frac {E}{RT^2_a} *(T - T_a) [/tex]
    y (although i used a different variable) is known as the frank kamenetskii parameter
    [tex] y = \frac {Q}{d}*\frac {E}{R*T^2_a}*r^2*z* exp(\frac {-E}{RT_a}) [/tex]
    E: activation energy
    T_a: ambient temperature
    Q: heat released
    z: frequency of particle collision
    r: radius or half width (depending on geometry)
    R: gas constant
    d: thermal conductivity
    all uniform except Q, i think..
    the book solves the differential equation 1, analytically, for a function [tex] \theta = f(y,x') [/tex] in case of high activation energy E. RT<<E
    the book gives the following result.
    [tex] exp(\theta) = \frac {a}{cosh^2(b \frac{+}{-} \sqrt \frac{a*y}{2} * x')} [/tex]
    im just trying to figure out what steps I need to take in order to arrive at the last solution.
  5. Nov 23, 2009 #4
    theta is the nodimensialization of the temperature.
Similar Discussions: Heat equation differentiation
  1. Heat equation (Replies: 2)
  2. The heat equation (Replies: 17)
Loading...
