What are the considerations for using stainless steel in heat exchanger tubes?
In summary, the conversation discusses the use of interstage coolers for a Synthesis gas compressor. The coolers are made of carbon steel, but due to corrosion in the tube to tubesheet joint, the speaker wants to use stainless steel instead. However, the vendor has expressed concern about the possibility of crevice corrosion. The speaker mentions that stainless steel is not a guarantee against corrosion and that the specific composition of the stainless steel and the fluids it will be exposed to must be considered. The quality and method of welding also play a role in corrosion. The speaker advises conducting a full check of alloy compatibility before making a decision.
m.a.tarafdar
We have 3 interstage coolers for a Synthesis gas compressor.Synthesis gas is mostly H2 & N2 with small Ar & CH4.Tube side fluid is water & shell side fluid is Syn.gas.The heat exchangers are made of carbon steel.Now due to corrosion in tube to tubesheet joint we like to use SS for tubes.But our vendor dont' agree & mentioned that there will be a chance of crevice corrosion.Is there any real reason for vendor's concern?
You don't plan to weld stainless on carbon steel, do you? This wouldn't work.
Generally, I expect stainless to perform better than carbon steel, BUT stainless isn't a general guarantee! Corrosion depends on the chemicals and the temperature, for instance water composition changes everything. The material and quality of the welds, even their heat history, are important. Hundreds of different stainless compositions are used, with very different corrosion properties.
For instance, stainless scissors in sea water would last few weeks. Or weld joints in normal 10-8 stainless would corrode in sweet water, but low-carbon variants improve it.
So you can't avoid the full check of alloy compatibility with your fluids and your welding method.
1. What materials are commonly used for heat exchanger tubes?
Some of the most commonly used materials for heat exchanger tubes are stainless steel, copper, titanium, and nickel alloys. Each material has its own unique properties and is chosen based on the specific requirements of the heat exchanger.
2. How do I choose the right material for my heat exchanger tubes?
The choice of material for heat exchanger tubes depends on factors such as operating temperature, pressure, corrosive environment, and cost. It is important to consult with a materials expert to determine the best material for your specific application.
3. What are the advantages of using stainless steel for heat exchanger tubes?
Stainless steel is a popular choice for heat exchanger tubes due to its high strength, corrosion resistance, and thermal conductivity. It is also relatively easy to fabricate and has a long lifespan, making it a cost-effective option in the long run.
4. Can heat exchanger tubes be made from multiple materials?
Yes, it is possible to have heat exchanger tubes made from multiple materials. This is known as a bimetallic or multilayered tube and is often used in applications where one material may provide better corrosion resistance or thermal conductivity than the other.
5. How do I ensure the longevity of my heat exchanger tubes?
To ensure the longevity of heat exchanger tubes, it is important to consider factors such as material selection, proper design, and regular maintenance. Properly chosen and maintained tubes can last for many years, reducing the need for frequent replacements.
  • Materials and Chemical Engineering
  • Mechanical Engineering
15K
  • Thermodynamics
  • General Engineering
10K
