Homework Help: Heat flow equation: solid
  1. Dec 9, 2007 #1
    If temperature T in a solid is constant over any x,y plane show that the temperature and heat flow Q normal to x,y planes both satisfy the equation:
    del^2 T=D dT/dt where D is a constant.
    How would you expect the differential equations to be modified if it were necessary to take account of the finite speed at which mechanical energy is transmitted in a solid?
    2. Relevant equations
    J= K gradT
    div J + C dT/dt =0
    3. The attempt at a solution
    It's easy to combine the two equations above to get the first part of the solution. However I don't reallty have a clue about the second part. I think the key point is that we're dealing with a solid not a gas like I'm used to, but I don't know what to do next.
    Maybe the finite speed puts a delay in the heat flux occuring relative to the gradient existing, but I'm not sure how to make this exact.
    Any help appreciated,
    Thanks
Draft saved Draft deleted
