Homework Help: Heat generated in the circuit
  1. May 15, 2014 #1
    How much heat is generated in the circuit after the switch is shifted from position 1 to 2?
    2. Relevant equations
    3. The attempt at a solution
    Let the charge on the right cap be Q(+Q on bottom plate) , on middle be Q-Q1(-Q+Q1 on bottom plate) and Q1(-Q1 on bottom plate) on left plate .
    Ceq = C(C+C0)/(2C+C0)
    Q=VC(C+C0)/(2C+C0)
    Q1=VC/(2C+C0)
    Q-Q1 = VCC0/(2C+C0)
    Now when the switch is at position1,charge on the bottom plate of left cap is -Q1 and after the switch is moved to position 2 charge is -Q i.e charge Q-Q1 has flown through the battery .In other words negative charge of magnitude Q-Q1 flows from positive to negative terminal of battery(current flows from negative to positive terminal) i.e work done by battery is (Q-Q1)V .
    Work done by battery = Change of energy stored in the capacitors + heat dissipated .
    So,heat dissipated = Work done by battery - Change of energy stored in the capacitors .
    Change of energy stored in the capacitors will be zero .
    Heat dissipated = Work done by battery = (Q-Q1)V = V2CC0/(2C+C0) .
    Is the answer correct ?
    Have I approached the problem correctly ?
  3. May 15, 2014 #2
    haruspex
    That looks right to me.
  4. May 15, 2014 #3
    rude man
    Yes. Any finite battery resistance will dissipate the same amount of energy. Interesting problem.
    (I did not check the delta stored energy).
  5. May 15, 2014 #4
    Thanks haruspex and rude man .
    Do you agree that if the switch were initially at position 2 and moved from position 2 to 1 then in that case also the result obtained in the OP would remain same ?
  6. May 15, 2014 #5
    I haven't checked all the math but the approach seems correct. The equation you provided for Q1 is missing something. The units don't match.
  7. May 15, 2014 #6
    haruspex
    Yes, it's symmetric.
  8. May 16, 2014 #7
    Thanks everyone for your valuable inputs .
  9. May 16, 2014 #8
    NascentOxygen
    Staff: Mentor
Have something to add?
Draft saved Draft deleted
Loading...
