Heat in atmosphere
  • Thread starter Hepic
Hepic
118
Heat is more in ground than in mountains.
Why? Mountains are nearer to sun,then what happens?
Thanks!!!
Answers and Replies
phinds
Insights Author
2021 Award
17,914
10,110
Thanks!!!
Do you have a source for that statement? If so, perhaps the source explains it.
Pythagorean
287
Mountains are more exposed to the elements and have lots of surface area per volume, making heat loss (through surface) faster and heat storage (through volume) smaller.
Hepic
118
Thank you Khashishi. So the answer is "pressure" and that "in high altidutes is harder to be kept the energy."
I ask you because I am bad in english,so I want to know If I undestood everything.
Thanks!!!!
dauto
1,948
201
To be clear, just being at higher pressure doesn't necessarily require the temperature to be higher. But imagine that there are circulating air currents up and down the atmosphere. When an air mass rises, it will expand due to the smaller pressure up there and will lose energy (not as heat, but as work). That's called expansional cooling. The opposite happens on the way down when the air mass gets compressed under the higher pressure increasing in temperature as it gains energy (again, as work - not heat). That's called compressional warming. Note that the presence of circulating air currents is important for that argument to make sense. The lowest layer of the atmosphere where we live - the troposphere - has those circulating currents (we call them convection) and has its temperature drop steadily with altitude (most of the time). But the layer above the troposphere - the stratosphere - does not. Turns out temperature in the Stratosphere actually increases with altitude.
dauto
1,948
201
The answer provided by Paul Shepson in your link is correct but the one provided by Michael Tinnesand isn't.
here is the quote
Michael Tinnesand said:
The basic answer is that the farther away you get from the earth, the thinner the atmosphere gets. The total heat content of a system is directly related to the amount of matter present, so it is cooler at higher elevations.
That answers is NOT correct.
dauto
1,948
201
That answer is not correct
dauto
1,948
201
Thanks!!!
One more thing. You mentioned the fact that the mountain is closer to the sun. This effect is completely negligible. The height of a tall mountain is about 10 km. The distance to the sun is about 150 000 000 km
Hepic
118
Why different things happens in stratosphere?
dauto
1,948
201
The Troposphere is heated from below. That promotes convection. The Stratosphere is heated from above.
Suggested for: Heat in atmosphere
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
13K
