Is Mylar Necessary for Preventing Heat Leak in Low Temperature Apparatus?
  • Thread starter Rajini
  • Tags
    App Heat
In summary: Thin sheets of aluminium foil or mylar are used to reduce the amount of heat that is transferred to the cryo. It is also possible to use a sacrificial cryogen (liquid nitrogen) to reduce the amount of heat loss. Alternatively, a 'cold head' can be used to reduce the amount of heat loss.
Rajini
621
Dear all,
i noticed in all low temp. apparatus like cryo...usually all the internal parts are wrapped with few thin mylar sheets in order to avoid heat leak (heat from surrounding is transferred to cryo)..also some ppl. told me it is for radiation (or thermal) shield..
Even though the cryo is in good vacuum...is these mylar is necessary? (i never tested without mylar)..Is there any good article discussing about these simple things..
thanks
Science news on Phys.org
Hi Rajini. A conventional, vacuum jacketed (VJ) tank or pipe system is actually two vessels, one inside another. A VJ pipe for example, has one pipe inside another which is supported by some kind of low thermal conductivity spacer. Similarly, a tank will have one tank inside another with some kind of low thermal conductivity suspension system.
Within this annular space is a vacuum. Typical vacuum (warm) is around 10 to 100 micron. Typical vacuum cold (at cryogenic temperature) is less than 1 micron. This vacuum space is intended to prevent any kind of conductive or convective heat transfer. There is no significant convective heat transfer unless the vacuum is lost (ex: due to a leak or out gassing of contaminants). Thermal conductivity is minimized by maximizing the length of the supports and minimizing the thermal conductivity of those supports.
To further reduce heat transfer, one has to do something about the radiation heat transfer. This is accomplished by providing layers of a reflective substance such as aluminized mylar or aluminum foil with a layer of non thermally conductive material that looks and feels like paper of some kind. Typical VJ pipe and tanks have about 60 such layers per inch, and may have anywhere between 10 layers on up to a hundred or so depending on the application. This type of insulation is known as Multi Layer Insulation (MLI). How these MLI systems are designed is generally proprietary, but they are all similar in their construction.
An alternative to MLI is the use of a more conventional insulation such as fiberglass matting or Perlite which is a type of volcanic rock. You can read more about it here:
http://en.wikipedia.org/wiki/Perlite
There are additional things that can be done to further reduce heat transfer, the most important being some kind of shielding which can be combined with either a sacrificial cryogen (typically liquid nitrogen) or a "cold head" which is a type of cryogenic refrigerator that uses helium in a closed loop system similar to a conventional air conditioner.
A good overview of cryogenic systems and MLI insulation in general is covered by a book called "Cryogenic Systems" by Randall Barron.
http://www.oup.com/us/catalog/general/subject/EngineeringTechnology/MechanicalEngineering/?view=usa&ci=9780195035674
Hi thanks for your comments.
Main aim is just to eliminate the radiative heat loss.
1. What is heat leak in low temperature applications?
Heat leak in low temperature applications refers to the transfer of heat from a warmer environment to a colder one, resulting in a rise in temperature in the colder environment. This can be problematic for applications that require extremely low temperatures, such as in cryogenic systems.
2. What causes heat leak in low temperature applications?
Heat leak in low temperature applications can be caused by a variety of factors, such as improper insulation, thermal bridges, air infiltration, or inadequate sealing. These can result in the transfer of heat from the outside environment to the low temperature environment.
3. How does heat leak affect low temperature systems?
Heat leak can significantly impact the performance of low temperature systems, as it can lead to an increase in temperature and compromise the stability and accuracy of the system. It can also result in higher energy consumption and increased costs for maintaining low temperatures.
4. How can heat leak be prevented in low temperature applications?
To prevent heat leak in low temperature applications, proper insulation and sealing techniques should be employed. This can include using materials with low thermal conductivity, such as vacuum insulation panels, and ensuring that there are no gaps or thermal bridges in the system. Regular maintenance and monitoring can also help identify and address potential sources of heat leak.
5. Can heat leak be completely eliminated in low temperature applications?
While it may not be possible to completely eliminate heat leak in low temperature applications, it can be significantly reduced through proper design, insulation, and maintenance. It is important to regularly monitor and address any potential sources of heat leak to ensure the optimal performance and efficiency of low temperature systems.
  • Thermodynamics
12K
  • Thermodynamics
  • Astronomy and Astrophysics
  • General Discussion
