Heat Loss Experiment: Explaining Results with Ideas
In summary, the conversation discussed the results of an experiment where water was cooled from 70 degrees to 65 degrees C in different materials. The results showed that the container with no material cooled the quickest, followed by aluminium foil, black paper, and bubble wrap. The discussion explored possible explanations for these results, including the role of convection and emissivity in each material. The conversation also touched on the use of foil blankets by athletes and their effectiveness in reflecting infrared heat. Further research and questions were suggested to better understand the results.
Jimmy87
686
We recently did an experiment in class and we were asked to get some ideas together to try and explain our results. We measured the time it took water to fall from 70 degrees to 65 degrees C. The water was placed in a shiny steel container (which had a volume of about 400ml). We half filled it each time and wrapped different materials around it. The first time we used no material (so just the metal can). Then we put bubble wrap around it, then black paper and finally aluminium foil. The results we found are in order of quickest to slowest fall from 70 to 65 degrees: no material, aluminium foil, black paper, bubble wrap.
None.
By doing some research I have some ideas. I think they all should have the same amount of convection loss from the top of the can. I think when no material was used it cooled quickest because the metal can conducted the heat to the outside of the can the quickest which meant a bigger loss from convection around the outside of the can. I'm confused about why the foil was still quick because athletes used foil blankets to reflect the infrared back to their body so shouldn't the foil wrapped around the can have worked in a similar way. Foil has a real low emissivity (0.1) so shouldn't it have retained 90% of the infrared heat from the water? I thought black had a really high emissivity which is why they use it for radiators so shouldn't it have emitted a lot of the heat away from the can?
None.
Excellent experiment!
Pretty much.
This sounds logical.
Sounds very logical, also.
Three questions:
A. How tightly do athletes wrap these blankets around themselves, compared to how tightly you wrapped your foil around the container?
B. Are these blankets really just only foil?
C. What's the thermal conductivity of aluminum, and how does that compare to its emissivity?
This is an excellent question.
You might try googling; Why do they paint radiators black?
OmCheeto said:
Excellent experiment!Pretty much.This sounds logical.Sounds very logical, also.
Three questions:
C. What's the thermal conductivity of aluminum, and how does that compare to its emissivity?This is an excellent question.
Thanks for your guidance - much appreciated!
A. I would guess I would have wrapped it tighter than an athlete would. So does this mean that an athlete would have a layer of air in between them and the blanket to serve as an insulator. Therefore it reflects radiation with little conduction. So if it is tighter in the experiment then are you trying to say it will be similar to when there is no material because you are just adding another conducting layer?
B. Not sure - couldn't find much.
C. Thermal conductivity of aluminium is very high. Emissivity is very low (0.04).
I'm still a bit confused though. If the foil has a really low emissivity then very little heat will be radiated away. However, since it is a good conductor there will be a lot of heat loss from around the outside of the can as mentioned earlier. So I guess the loss from conduction to the air is much higher that is doesn't really matter that it has low emissivity? Could you say the same about the black card. The conduction is so slow through the card that not much is lost to convection around the outside and the high emissivity doesn't really contribute much loss? It's so confusing!
Yes.
hint: We used to call them "Space Blankets".
My guess is that your guess is correct, but I've actually never done a calculation of radiant heat loss.
I don't think your instructor would like that answer; "Everyone unanimously guesses that we are correct".
But last week I did an experiment that very similar to yours.
From the data you collected, you should be able to determine, at least roughly, the amount of energy that was lost via radiation.
I will do the same. (My setup used a glass container and 100 ml of water, heated to boiling.)
Like your athlete in the aluminum blanket, anywhere the material is not in contact with the steel jar is going to have an air space. And "air" is an exceptional insulator.
OmCheeto said:
Yes.
hint: We used to call them "Space Blankets".My guess is that your guess is correct, but I've actually never done a calculation of radiant heat loss.
Thank you once again for your help! Could you kindly explain how you would work out the radiant loss? I'm not sure how you isolate this from the convection loss from the outside of the can?
As I said yesterday, I've never studied radiant heat loss, so everything I am about say, I've learned in the last 12 hours. (Which means the Mentors and HW Helpers should keep a very close eye one me! :biggrin: )
From wiki's entry on "Thermal Radiation", I found an equation: P = ε ⋅ σ ⋅ A ⋅ T4 (grey body radiation)
I interpret this as Power(P) = emissivity(ε) ⋅ Stefan-Boltzmann constant(σ) ⋅ area(A) ⋅ temperature(T, in Kelvin)
From my setup, I was able to determine that more than half of the energy from my system was being lost via radiation!
Needless to say, I was quite surprised.
Now you, as I, have a bunch of data which gives the temperature of our setups at specific moments in time.
From that data, we can determine P(power).
And given that we have "Power" and "time" we can figure out energy.
And beings that someone in the past said; "Energy is conserved", I concluded that "total energy loss" - "theoretical radiative energy loss" = "energy loss due to convection".
Well... I hope you see it.ps. Jimmy87, I've checked out the threads you've started, and have decided that you should be teaching me.
pps. Mentors, as always: ok to delete, infract, and ban. Or send me a polite reminder, not to have so much fun, attempting to solve student's problems. :redface:
Likes Jimmy87
From wiki's entry on "Thermal Radiation", I found an equation: P = ε ⋅ σ ⋅ A ⋅ T (grey body radiation)
I may be being a bit slow but I thought radiative heat loss is the heat loss through infrared radiation (linked to emissivity) and convection is convection and completely different. You have said that radiative energy loss = energy loss due to convection - I don't see how that works? I see it as:
total heat loss = convection from outside of the can + heat lost from infrared radiation + convection from the top of the can (+ conduction to the table)
Yes.
Yes.
I'm not seeing where I said that.
I think we need to slow down here.
I said; "total energy loss" - "theoretical radiative energy loss" = "energy loss due to convection"
which is equivalent to
"total energy loss" = "theoretical radiative energy loss" + "energy loss due to convection".
Which is what you've basically said. (sans the conduction, et al, of course).
convection from outside of the can + convection from the top of the can = energy loss due to convection.
ps. You forgot to mention the heat capacity of your vessel. My vessel accounted for 1/11th of the energy change of my system, as far as I can tell:
836 joules: water
84 joules: container
So I threw that out.
Likes Jimmy87
OmCheeto said:
Yes.
Yes.
I'm not seeing where I said that.?
836 joules: water
Ha, what a clown I am! Sorry I didn't see the minus sign! So to find the energy lost to radiation I simply do the following:
surface area of the can x Boltz constant x emissivity of can's material x temperature to the power of 4 (in Kelvin) of the can.
I'm guessing the temperature T is the change in temperature? So you then multiply this power by the time it took to create that temperature change to give to total radiative loss? How do you work out the total energy loss from the system? Is it just the energy loss from the water which you calculate using specific heat capacity?
Yes, and thanks. I fixed the error.*
No.
Yes and no, as ambient temperature also comes into play.
Th-Tc, mass and composition of the system, and a bunch of maths.
No.
Sorry to be so succinct, but it's time for my nap.
*This will probably be the last homework problem I get involved in. My error rate is way too high. Thank god I've got 6 year old grand-kids.
Likes Jimmy87
1. What is a heat loss experiment?
A heat loss experiment is a scientific investigation that measures the amount of heat lost from an object or system over a period of time. This can be done by using various tools and techniques, such as thermometers, thermal imaging cameras, and calorimeters.
2. How is heat loss measured in an experiment?
Heat loss is typically measured in an experiment by calculating the difference in temperature between the initial state and the final state of the object or system being studied. This change in temperature, along with the time elapsed, can be used to determine the rate of heat loss.
3. What factors can affect the results of a heat loss experiment?
There are several factors that can affect the results of a heat loss experiment, including the type of material being studied, the temperature difference between the object and its surroundings, the surface area of the object, and the insulating properties of the environment.
4. How do scientists explain the results of a heat loss experiment?
Scientists use various theories and concepts, such as thermodynamics and heat transfer, to explain the results of a heat loss experiment. They also take into account the specific conditions and variables of the experiment to determine the most accurate explanation for the observed results.
5. What are some potential applications of heat loss experiments?
Heat loss experiments have many practical applications, including improving energy efficiency in buildings and vehicles, designing better insulation materials, and understanding the impact of climate change on different systems and organisms. They also help scientists gain a better understanding of the fundamental laws of thermodynamics and heat transfer.
  • Other Physics Topics
  • General Engineering
