How Do You Calculate Heat Loss from a Box and Heated Gas?
In summary, the conversation discusses determining the heat loss from a box containing a heat source and calculating the heat/energy loss of a heated gas into ambient air. This topic is typically covered in mechanical or chemical engineering classes rather than physics classes. It is suggested to ask for assistance in the engineering section for more specific information.
nuby
336
Hello,
How can I determine the heat loss (to air) from a box of a specific material, with a heat source inside of it?
Also, how do you calculate the heat/energy loss of a heated gas into ambient air.
Thanks
This is usually not treated in physics classes, rather in mechanical or chemical engineering classes that deal with heat transfer by convection.
Is this a specific homework problem, or just for general knowledge? At any rate, you're probably better off asking in the engineering section.
Of course, the steady state heat loss rate would equal the heat generation rate, but that's probably not very helpful.
for your question. To determine the heat loss from the surface of a box, you will need to consider several factors such as the thermal conductivity of the material, the temperature difference between the inside and outside of the box, and the surface area of the box. The formula for calculating heat loss is Q = kA(T1-T2)/d, where Q is the heat loss, k is the thermal conductivity, A is the surface area, T1 is the inside temperature, T2 is the outside temperature, and d is the thickness of the box. You can also use this formula for calculating the heat loss from a heated gas into ambient air by substituting the thermal conductivity of the gas for k and the volume of the gas for A. It's important to note that this formula is a simplified version and may not account for all factors, so it's best to consult a more comprehensive heat transfer equation for more accurate results. I hope this helps.
1. What is heat loss from box surface?
Heat loss from box surface refers to the amount of heat that is transferred from the surface of a box to its surroundings. This can occur through conduction, convection, or radiation.
2. How does the material of the box affect heat loss?
The material of the box can greatly affect the rate of heat loss. Materials with high thermal conductivity, such as metals, will transfer heat more easily than materials with low thermal conductivity, such as plastics or insulating materials.
3. What factors influence heat loss from box surface?
The rate of heat loss from a box surface is influenced by several factors, including the temperature difference between the box and its surroundings, the surface area of the box, the material of the box, and the presence of insulation.
4. How can heat loss from box surface be reduced?
There are several ways to reduce heat loss from a box surface, including using insulating materials, minimizing the surface area of the box, and reducing the temperature difference between the box and its surroundings.
5. Why is it important to minimize heat loss from box surface?
Minimizing heat loss from a box surface is important in order to maintain the desired temperature inside the box. This is especially important for items that are sensitive to temperature changes, such as food or medication, as well as for energy efficiency purposes.
  • General Engineering
