Heat Loss
  • Thread starter Cheddar
Cheddar
38
A metal (doesn't say what metal) is in a heater that is set to 700 K.
If the temperature of the ball is 900 K then the rate of heat loss = 0.10 J/min.
What is the rate of heat loss when the ball's temperature = 800 K.
The ball's emissivity doesn't change appreciably with temperature.
Q = emissivity * Boltzman Law * Temperature (to the 4th power in K) * Area * time
I solved for A using the given information then plugged it into the equation above to solve for Q/t using 800 K instead of the 900 K. My answer doesn't check out. Am I suppose to convert 0.10 J/min into J/seconds? If so, how?
Answers and Replies
tiny-tim
25,838
255
Hi Cheddar! :smile:
… If the temperature of the ball is 900 K then the rate of heat loss = 0.10 J/min.
Yes, all your measurements must be in SI units (kg, second, joule, etc).
Calculations can go horribly wrong if you don't do that!
To convert J/min into J/second, just do it the same way you'd convert feet/min into feet/second. :wink:
Cheddar
38
Thank you. I did that and the answer still doesn't match up though.
I get an area of 4.48018196 * 10(-8 power). Plugging this into:
Q/t = emissivity * Boltzman's * Temperature(4th power) * Area
leaves me with 0.0010404918, which doesn't check out.
Redbelly98
Staff Emeritus
Insights Author
12,145
166
This equation isn't quite right. Question: what would the rate of heat loss be if the ball were at the same temperature as the heater in which it is located?
Cheddar
38
So, instead of T(4th power) it should maybe be the difference between the ball's temp and the environments temp(to the 4th power)??
Redbelly98
Staff Emeritus
Insights Author
12,145
166
Close. It would be (Tball4 - Tenvir4)
Cheddar
38
I think I have it.
0.40 J/min
Redbelly98
Staff Emeritus
Insights Author
12,145
166
The heat loss rate should be less at a lower temperature.
Suggested for: Heat Loss
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
