1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Heat loss
  1. Feb 20, 2016 #1
    Hello everyone, I hope that you guys could lend me a hand.
    I need to calculate the heat loss at any point over a long pipe while considering lambda of the pipe. I am trying to use octave to find a reasonable flow-rate to keep the temperature loss to a minimum at a reasonable pressure.
    lambda= 0.02
    inner radius=0.1m
    outer radius=0.2m
    Distance=4000m
    initial inside temperature 100C
    outside temperature=10C
    Assumptions:
    laminar flow.
    no vertical variations.
    2. Relevant equations
    3. The attempt at a solution
    %Heat loss long distance transfer
    %Initial Settings
    PipeRadiusInside=0.1;
    PipeRadiusOutside=0.2;
    TotalPipeDistance=1000;
    Time=1;
    PipeSegmentLength=16;
    OutsideTemperature=10;
    InsulatingCapacity=0.020;
    Temperature=[];
    CurrentTemperature=100;
    i=0;
    PipeThickness=PipeRadiusOutside-PipeRadiusInside;
    Resistance=((PipeThickness*log(PipeRadiusOutside/PipeRadiusInside))/InsulatingCapacity); U=1/Resistance;
    TemperatureDifference=CurrentTemperature-OutsideTemperature; SegmentVolume=2*pi*PipeSegmentLength; EnergyOfWater=4.2*TemperatureDifference*SegmentVolume*0.9982;
    while i<TotalPipeDistance/Time i=i+PipeSegmentLength; Temperature=[Temperature CurrentTemperature]; HeatLoss=2*pi*PipeRadiusOutside*U*TemperatureDifference*PipeSegmentLength; EnergyOfWater=EnergyOfWater-HeatLoss; CurrentTemperature=((EnergyOfWater-HeatLoss)/(4.2*SegmentVolume*0.9982))+OutsideTemperature; TemperatureDifference=CurrentTemperature-OutsideTemperature;
    end plot(Temperature)
    It gives me results which look like the could be right as it reacts to changes in variables correctly but it is definitely incorrect. Also I do not know how to relate it to flow rate.
    I really need help and would be thankful for an example.
    Thank you for your time.
  3. Feb 20, 2016 #2
    SteamKing
    Staff Emeritus
    Does lambda have any units associated with it?
  4. Feb 21, 2016 #3
    Yes. Sorry I forgot to mention that. (w/mK)
Have something to add?
Draft saved Draft deleted
Similar Discussions: Heat loss
  1. Losses in transformers (Replies: 5)
  2. Power loss in a cable (Replies: 5)
Loading...
