Can the heat of combustion only be found experimentally?
In summary, the heat of combustion of ethanol can be found experimentally, but the enthalpy of formation of ethanol must be calculated using experimental data.
gfd43tg
50
Hello,
Can the heat of combustion only be found experimentally? I am looking on this page at the heat of combustion of ethanol
http://www.ausetute.com.au/heatcomb.html
and I see that ##\Delta H^{o}_c = 1368 \hspace{0.05 in} kJ/mol##. But if you calculate from its constituents
##C_{2}H_{6}O (l) + 3O_{2} (g) \rightarrow 2CO_{2} (g) + 3H_{2}O (l)##
The enthalpy of formation (calculated the same way as enthalpy of combustion??) is using the equation
[tex]\Delta H^{o}_{rxn} = \sum_{products} \nu_{i} \Delta H_{i}^{o} - \sum_{reactants} \nu_{i} \Delta H_{i}^{o}[/tex]
where ##\nu_{i}## is the stoichiometric coefficient of a chemical species ##i##
##[\Delta H_{f,ethanol}^{o} + 3(0 \hspace{0.05 in} kJ/mol)] - [(2)(-393.5 \hspace{0.05 in} kJ/mol) + 3(-285.8 \hspace{0.05 in} kJ/mol)] = 1368 \hspace{0.05 in} kJ/mol##
##\Delta H_{f,ethanol}^{o} = -276.4 \hspace{0.05 in} kJ/mol##
But to calculate the heat of formation of ethanol assumes a priori that you know the heat of combustion of ethanol. So is there a mathematical or theoretical way to calculate the heat of combustion, or is it purely from experiment?
Chemistry news on Phys.org
In theory one should be able to find bonding energy of all molecules involved using QM approach. If memory serves me well this never works perfectly (which I understand as "we are not there yet"). So we stick with methods that use some kind of experimental data.
But I am not confident in what I know, I can be missing some new developments.
Likes gfd43tg
This is also a question on the number of significant figures wanted and the availability of experimental data.
Quantum chemical calculations are used mainly to predict the heat of combustion of substances which haven't been synthesized yet. Google will spit up a lot of literature.
I think for my purposes it will just be experimental. I had always been confused between heats of combustion and heat of reaction. It seemed like they were identical, with the exception that a special name was given to reactions that involve combustion with oxygen. Maybe I was doing some mix up with heat of formation and heat of reaction.
If you have the heats of formation of the reactants and products of a reaction, then you can determine the heat of reaction. That is the power of tabulating heats of formation of species. Sometimes the heat of formation of a species (that goes into a heat of formation table) can be backed out of the heat of combustion, or from the heat of some other reaction that the species participates in. So some experiments are required to get heats of formation. But the advantage is that, by tabulating heats of formation, you don't have to measure the heat of every possible reaction. You only need to do enough experiments to measure the heats of formation. You can then use this data in predicting heats for reaction for reactions that have never been experimentally measured. This is a tremendously powerful tool for accurately predicting heat effects in chemical process calculations.
Chet
See, if you think of heat of reaction and heat of combustion as being the same thing, then there is a paradox.
To calculate the heat of reaction, you need the heat of formation. But to calculate the heat of formation, you need the heat of combustion.
Apparently, I didn't explain very well in my previous post. Measuring heat of combustion is not the only way to get the heat of formation of a substance. The idea is to get the heats of formation of substances by doing a minimum number of experiments. To see a better explanation than mine, see Smith and van ness.
Which is why we choose an arbitrary reference of zero for the elements in their most stable form.
I was reading smith and van ness section on Heat of Combustion (chapter 4, section 5 in the 7th edition) before I created this thread, which is what started this whole thing. The issue is how the number for the combustion of n-butane just comes out of nowhere. I know how they got the heats of reaction for the first two reactions. But 2,877,396 kJ/mol just seems to be placed in their with no justification.
Looks like the combustion of butane, just reversed (flip the sign).
Okay forget about it, this is just going around in circles. I'm just going to accept that the enthalpy of combustion of a species is determined experimentally and should be looked up. Thank you!
Yes, heat of combustion is usually determined experimentally. It is a pretty trivial measurement by today's standards and very accessible. I think you may have it a little backwards.
To determine the heat of formation of butane, you need to have graphite and hydrogen gas in their standard states and react to form butane. Well good luck getting that done experimentally, it is not trivial. What is trivial is combusting butane (thereby getting the heat of combustion) and calculating the heat of formation from the chemical equation and the equation for hear of reaction (of which combustion is a special case). You will have 4 species in your chemical equation, oxygen (zero Hf), water (tabulated), carbon dioxide (tabulated), and butane. You can then solve for the heat of formation of butane by doing a relatively simple measurement, and looking up well known values, instead of having to figure out how to make butane from all of its elements in their standard state.
Likes mheslep
Yanick is right on target. I think the question is "where did the number for the heat of formation for butane that is listed in the table come from?" That answer was that, if you know the heat of formation of water and carbon dioxide, and you measure the heat of combustion of butane, you can back out the heat of formation of butane.
Chet
1. What is the heat of combustion?
The heat of combustion is the amount of heat released when a substance is completely burned in oxygen under standard conditions. It is a measure of the energy content of a substance.
2. How is the heat of combustion measured experimentally?
The heat of combustion can be measured experimentally by using a bomb calorimeter, which is a device that allows for the complete combustion of a substance in an isolated environment. The heat released is then measured and used to calculate the heat of combustion.
3. Can the heat of combustion be calculated theoretically?
Yes, the heat of combustion can be calculated theoretically using the enthalpy of formation of the substance and the balanced chemical equation for the combustion reaction. However, experimental values are often more accurate due to factors such as incomplete combustion and heat loss during the experiment.
4. Why is it important to know the heat of combustion of a substance?
The heat of combustion is important in various industries such as energy production, fuel development, and chemical reactions. It helps determine the efficiency of a substance as a fuel source and can also provide insights into the environmental impact of its combustion.
5. Can the heat of combustion vary for the same substance?
Yes, the heat of combustion can vary for the same substance depending on factors such as the purity of the substance, the amount of oxygen present during combustion, and the temperature at which the reaction occurs. This is why experimental measurements are often preferred over theoretical calculations.
  • Thermodynamics
  • Materials and Chemical Engineering
