Calculating Temperature & Heat Transfer with a Piece of Metal
In summary, a piece of metal with a mass of 1.50 kilograms, specific heat of 200 J/kg · C°, and initial temperature of 100° C was dropped into an insulated jar containing liquid with a mass of 3.00 kilograms, specific heat of 1,000 J/kg · C°, and initial temperature of 0° C. After 5 seconds, the metal was removed and its temperature was 20° C. Neglecting any heat transfer to the air or insulated jar, the temperature of the liquid after the metal is removed is 8° C. The average rate at which heat is transferred while the piece of metal is in the liquid is 4,000 J/s.The
always_smile
A piece of metal with a mass of 1.50 kilograms, specific heat of 200 J/kg · C°, and initial temperature of 100° C is dropped into an insulated jar that contains liquid with a mass of 3.00 kilograms, specific heat of l,000 J/kg · C°, and initial temperature of 0° C. The piece of metal is removed after 5 seconds, at which time its temperature is 20° C. Neglect any effects of heat transfer to the air or to the insulated jar.
What is the temperature of the liquid after the metal is removed ?
a.) 0° C
b.) 4° C
c.) 8° C
d.) 10° C
e.) 20° C
What is the average rate at which heat is transferred while the piece of metal is in the liquid ?
a.) 4,000 J/s
b.) 4,800 J/s
c.) 6,000 J/s
d.) 9,600 J/s
e.) 16,000 J/s
i have no idea what i should do
please help me
thanks
Read the forum rules please. We cannot help you unless you show some proof that you have put effort into this problem, i.e. work. You do not necessarily need to have equations and numbers, but you must show that you have put some time into the problem posted.
Try to answer the following and then we'll be able to help you here:
1) What concepts apply here?
2)What actually happened to cause the metal to cool down and the water to heat up?
3) Now that you have answered the above and have a list of concepts that apply, do you know of any formulas or equations that describe some of these concepts quantitatively. If so, list them.If you can give an attempt at answering some of these questions, then we'll be able to help you.
I would approach this problem by using the equation Q = mcΔT, where Q is the heat transferred, m is the mass, c is the specific heat, and ΔT is the change in temperature.
To find the temperature of the liquid after the metal is removed, we can use the equation Q = mcΔT for both the metal and the liquid. Since the metal's initial temperature is 100°C and its final temperature is 20°C, we can calculate the heat transferred from the metal as follows:
Qmetal = (1.50 kg)(200 J/kg · C°)(20°C - 100°C) = -24,000 J
Since the heat lost by the metal is equal to the heat gained by the liquid, we can set Qmetal = Qliquid and solve for the final temperature of the liquid:
-24,000 J = (3.00 kg)(1000 J/kg · C°)(Tliquid - 0°C)
-24,000 J = 3,000,000 J/kg · C°(Tliquid)
Tliquid = -0.008°C
Since the temperature of the liquid cannot be negative, we can conclude that the final temperature of the liquid is 0°C. Therefore, the correct answer is option a) 0°C.
To find the average rate at which heat is transferred while the metal is in the liquid, we can use the equation Q/t = mcΔT/t, where t is the time. Since the metal was in the liquid for 5 seconds, we can calculate the average rate of heat transfer as follows:
Q/t = (1.50 kg)(200 J/kg · C°)(20°C - 100°C)/5 s = -4,800 J/s
Therefore, the correct answer is option b) 4,800 J/s.
In conclusion, as a scientist, I would use the appropriate equations and calculations to determine the temperature of the liquid after the metal is removed and the average rate of heat transfer during the process. It is important to carefully consider all the given information and use the correct units in the calculations to ensure accurate results.
1. How do you calculate the temperature of a piece of metal?
To calculate the temperature of a piece of metal, you need to know its mass, specific heat capacity, and the amount of heat it has absorbed or released. The formula for calculating temperature is: T = Q / (m x c), where T is the temperature in degrees Celsius, Q is the amount of heat absorbed or released in Joules, m is the mass of the metal in kilograms, and c is the specific heat capacity of the metal in Joules per kilogram per degree Celsius.
2. What is specific heat capacity and why is it important in temperature calculations?
Specific heat capacity is the amount of heat required to raise the temperature of one kilogram of a substance by one degree Celsius. It is important in temperature calculations because it helps to determine how much heat energy is needed to change the temperature of a given amount of a substance, in this case a piece of metal.
3. How does heat transfer affect the temperature of a piece of metal?
Heat transfer is the movement of thermal energy from a warmer object to a cooler object. In the case of a piece of metal, heat transfer can cause its temperature to increase or decrease depending on whether it is absorbing or releasing heat. If the metal is in contact with a hotter object, it will absorb heat and its temperature will increase. If it is in contact with a cooler object, it will release heat and its temperature will decrease.
4. What is the difference between conduction and convection in heat transfer?
Conduction is the transfer of heat through direct contact between two objects or substances. In the context of a piece of metal, this would involve the transfer of heat from one part of the metal to another. Convection, on the other hand, is the transfer of heat through the movement of a fluid (liquid or gas). This is why a metal object left in the sun will feel much hotter than the air temperature, as the air around it is being heated through convection.
5. How can you use temperature calculations to determine the heat capacity of a substance?
By measuring the mass and temperature change of a substance, and knowing the amount of heat absorbed or released, you can use the formula mentioned in question 1 to calculate the specific heat capacity of the substance. This can be useful in determining the efficiency of different materials in storing or releasing heat energy, as well as in designing heating or cooling systems.
