Heat problem
  1. Sep 30, 2009 #1
    You pour a certain amount of water at 100C and an equal amount of water at 20C into an insulated container. THe final temperature of the mixture will be (a) 60C (b) Less than 60C (c) greater than 60C.
    2. Relevant equations
    3. The attempt at a solution
    I don't know what formula to use. Can someone give me a hint.
  3. Sep 30, 2009 #2
    Delphi51
    The usual approach on these heat questions is to write this formula:
    Heat lost by first material = Heat gained by second material
    I trust you have a formula for calculating the heat when you have the temperature change.
  4. Oct 1, 2009 #3
    Kurdt
    Staff Emeritus
    Surely you have been learning about this in class. If not the correct equations are easily found with a google search.
Similar Discussions: Heat problem
  1. Heat problem (Replies: 1)
  2. Heat problem (Replies: 2)
  3. Heat problems (Replies: 1)
  4. Heat problem (Replies: 2)
Loading...
