1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Heat pump problem
  1. Jul 21, 2007 #1
    1. A heat pump is being used to keep the temperature inside a house at 23 C, while the tmeperature ouside is -6.0 C. The heat pump is providing heat inot the house at the rate of 8.8 kW with a coefficient of performance of 5.6.
    A) What power input (in KW) is needed to run the heat pump?
    B) What power input (in KW) would be needed if the heat pump were ideal and still providing 8.8 kW heating power inside the house?
    2. Relevant equations
    coefficient of performance = (QsubscriptH)/Work
    For ideal heat pump:
    (QsubscriptC)/(QsubscriptH)=(Temperature subcript C)/(Temperature subscript H)
    W=(QsubscriptH)-(QsubscriptC)
    3. The attempt at a solution
    convert Temperatures to Kelvin
    A) coefficient of performance = (QsubscriptH)/Work
    5.6=8.8 kW/W
    W=1.57 kW
    Would power input be work? or would you use the power equation?
    B) (QsubscriptC)/(QsubscriptH)=(Temperature subcript C)/(Temperature subscript H)
    (QsubscriptC)/8.8 kW=267 K/246 K
    (QsubscriptC)=7.94 kW
    =8.8 kW -7.94 kW
    =.86 kW
    Are my calculations correct?
  3. Jul 21, 2007 #2
    Andrew Mason
    A) is right. But in B, you are not converting the temperatures correctly. 23 C = 296 K and -0.6 C = 272.4 K.
    AM
  4. Jul 21, 2007 #3
    It should be -6.0 not -0.6. But anyways thanks so much!
Similar Discussions: Heat pump problem
  1. Heat Pump (Replies: 3)
  2. Heat pump problem (Replies: 0)
  3. Heat Pump problem (Replies: 2)
  4. Heat pump problem (Replies: 8)
Loading...
