Heat transfer to a water bath
  • Thread starter Physgeek64
A cylinder is fitted with a piston and is in thermal contact with a heat bath at 273K. Initially the volume in the cylinder is filled with 10kg of pure H2O and about half of this is liquid and the other half is solid. The piston is lowered so as to reduce the volume by 2 × 10−5 m3. What is the sign and magnitude of the heat transfer to the bath?
##\frac{dp}{dT}=\frac{L}{T\Delta V}##
##p_2-p_1= \frac{L}{\Delta V} ln{\frac{T_2}{T_1}}##
but ##T_1=T_2## hence ##p_1=p_2=constant##
##dQ=dU+pdV=C_VdT+pdV=pdV##
##\Delta Q=p\Delta V##
I feel this is probably all wrong, but i can't see how else to do it- any help would be very much appreciated.
Answers and Replies
mjc123
1,196
624
What are the densities of ice and water at 273K? How much ice must be converted to water, or vice versa, to reduce the total volume by 2 x 10-5 m3?
##V=\frac{M}{\rho}##
##\Delta V= \delta \big{(} \frac{1}{\rho_l} + \frac{1}{\rho_s} \big{)}##
where ##\delta## is the mass that is converted from solid to liquid.
## \delta= 9.58 \times 10^{-3}##
Can we then use ##lM=T\Delta S = \Delta Q##
##\Delta Q = l \delta = 3191.25 J## ?
where l is the specific latent heat of fusion of ice
mjc123
1,196
624
ΔV=δ(1ρl+1ρs)ΔV=δ(1ρl+1ρs)\Delta V= \delta \big{(} \frac{1}{\rho_l} + \frac{1}{\rho_s} \big{)}
(Why does it always look wrong in quotes?)
Why the plus sign? You want the difference in volume between liquid and solid.
Ahh yes!! So with the minus sign, does this look right?
Thanks
DrClaude
Mentor
7,627
4,068
Selecting text to quote appears to translate away from the underlying LaTeX. To get it to display properly, you have to use the Reply "button" on the lower right-hand side of the post. That will quote the entire post, but you can trim it down if you just want to quote a part.
mjc123
1,196
624
Should be. Be careful with the sign of Q.
Related Threads on Heat transfer to a water bath
  • Last Post
22K
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
