• Support PF! Buy your school textbooks, materials and every day products Here!
Heat Transfer
A thick wall cylinder having a thermal conductivity of 60W/mK has a 75mm inner diameter and is 2.5mm thick. The pipe carries water at 90 degrees celsius inside and the outside is surrounded by air at 20 degrees celsius.
The heat transfer coefficients inside and outside the hot water pipe are 500W m2 K and 35 W m2 K respectively. Natural convection can be ignored.
Calculate the heat loss in W per unit length of the pipe
q= K Delta U T1-T2/r1-r2 = T1-T2/r2-r/Kal
Alm = 2Pie Lr2- 2Pie Lr1/Ln(2(2{PieLr2/2pieLr1 [/B]
= A2-A1/ln(A2/A1)
q = 90-20/0.03875-0.037
60 * (2Pie x 1 x 0.03875- 2Pie x 1 x 0.03875)/
ln (2Pie x 1 x0.3875/2Pie x 1 x0.3875/2Pie x 0.3875
Answers and Replies
4,264
Your equations are unreadable. Please use the symbols provided with the ∑ sign on the tool bar, or use Latex. There is a LaTex tutorial available on our sight.
Regarding your calculations, you seem to have omitted the heat transfer resistance on the air side and on the fluid side, which are in series with the pipe wall. Also, for such a thin wall, there is no need to use the log-mean.
Related Threads on Heat Transfer
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
