Homework Help: Heating a room
  1. Nov 3, 2007 #1
    Imagine you've been walking outside on an cold winter's day. When you arrive home at your studio apartment, you realize that you left a window open and your 5 {\rm m} \times 5 {\rm m} \times 3 {\rm m} room is only slightly warmer than the outside. You turn on your 1-kW space heater right away and wait impatiently for the room to warm up.
    In this problem, make the following assumptions:
    * The entire 1\;{\rm kW} = 1000\;{\rm J/s} output of the space heater goes into warming the air in the room.
    * The air in the room is an ideal gas with five degrees of freedom per particle (three translational degrees of freedom and two rotational degrees of freedom--about right for nitrogen and oxygen).
    * At room temperature and atmospheric pressure, one mole of air fills a volume of 23 liters. This is slightly larger than the volume of air at standard temperature and pressure, because room temperature is hotter than 0^\circ {\rm C}.
    How long will it be before the heater warms the air in the room by 10 ^\circ {\rm C}?
    Express your answer in minutes, to the nearest integer.
    2. Relevant equations
    Q=mc(T2-T1)
    3. The attempt at a solution
    the mass of air = 29g/mol = 0.029Kg/mol.
    the volume is given to be 23 litres or 0.023m^3.
    Therefore, density = 1.26
    specific heat of air S = 1.0035 J g−1 K−1
    mass of the air enclosed in the room = desity * volume
    = 1.26 kg/m3 * 5m*5m*3m
    m = 94.5 kg
    heat reqiured to change the temperature of the room is
    Q = mSΔT
    = 94.5kg * 1003.5J kg−1 K−1 * 10 0
    = 948307.5J
    the power of the heater = 1kW
    time reqiired = t = 903150J / 1000 J /sec
    t = 948.3075 sec
    In minuted to nearest integer, this is 16.
    However, this is wrong.
    What should the correct answer be?
  3. Nov 3, 2007 #2
    mjsd
    how did u get this molar mass for air?
  4. Nov 3, 2007 #3
  5. Nov 3, 2007 #4
    mjsd
    ok, fair enough....
    now, how did you work out the specific heat for air?
  6. Nov 3, 2007 #5
    mjsd
    how did you get your value of [tex]\Delta T[/tex]?
  7. Nov 3, 2007 #6
    It says in the question:
    Specific heat i got from another website. dont remember!!
  8. Nov 4, 2007 #7
    mjsd
    while I do not know whether your specific heat value is correct or not, given that the question has told you that it is an idea gas and all that other info, I have got the feeling that you may have to work out c_v using formulas like these
    http://farside.ph.utexas.edu/teaching/sm1/lectures/node52.html
    note: it your case, there are 5 degrees of freedom for N_2 and O_2 are diatomic molecule
    anyway, a quick calculation, I've got after rounding: 11 mins.
    what is the given answer (if there is one)?
  9. Nov 4, 2007 #8
    Is this right:
    Cp - Cv = R
    Dividing by Cv and using the fact that Cp/Cv = gamma,
    You get Cv = R/(gamma - 1).
    Wait, whats the value of gamma for diatomic gases?
  10. Nov 4, 2007 #9
    Is this right:
    Cp - Cv = R
  11. Nov 4, 2007 #10
    mjsd
    note once you have worked out the value of c_v it should be in units of J/mol/K
    unless your R is given in other units.
    btw, is 11 mins the correct answer?
  12. Nov 4, 2007 #11
    Can you please tell me the method?
    The answer is not given! Btw,
    how did u get 11?
    Cv comes to 20.755 ryt?
    then what?
Loading...
