Heating Water with Coal Gas: Calculating Gas Consumption
In summary, to heat 200 liters of water from 100 to 65 degrees Celsius by burning coal gas, with a heat loss of 25% in the chimney, 3.4 cubic meters of gas are needed.
Karol
1,380
200 liters of water are heated from 100 to 650C by burning coal gas. The heat loss in the chimney is 25%.
How many cubic meters of gas are needed
Calories required: [itex]Q=mc\delta t[/itex]
Burning heat of coal gas: 4320[Cal/m3]
Net heat needed: [itex]Q=200\cdot 55=11,000[/itex]
Gross heat needed: [itex]Q\cdot 0.75=11,000\rightarrow Q=14,667[/itex]
Gas needed: [itex]4320\cdot x=14,667\rightarrow x=3.4[m^3][/itex]
It should be 2.9
You need to show units in all your calculations. It makes your work much easier to follow and analyze for mistakes.
Net heat needed: [itex]Q=200[kg]\cdot 55^0=11,000[Cal-kg][/itex]
Gross heat needed: [itex]Q[Cal-kg]\cdot 0.75=11,000[Cal-kg]\rightarrow Q=14,667[Cal-kg][/itex]
Gas needed: [itex]4320[Cal/m^3]\cdot x=14,667[Cal-kg]\rightarrow x=3.4[m^3][/itex]
It should be 2.9[/QUOTE]
You are missing something in the first formula. How can you get Calories by multiplying kg by degrees?
And how did the kg vanish again in the third line? This issue will go away once you fix the first line.
What should be 2.9?
I mistakenly omitted the specific heat:
Net heat needed: [itex]Q=200[kg]\cdot 1[\frac{Cal}{^0\cdot kg}]\cdot 55^0=11,000[Cal][/itex]
Gross heat needed: [itex]Q[Cal]\cdot 0.75=11,000[Cal]\rightarrow Q=14,667[Cal][/itex]
Gas needed: [itex]4320[Cal/m^3]\cdot x[m^3]=14,667[Cal]\rightarrow x=3.4[m^3][/itex]
The answer should be 2.9[m3]
Your answer is right, IMHO. Let's solve the problem by a false-position approach: we assume that you burn 2 cu. m of gas. The energy obtained is 4320*2 = 8640 Cal. You lose 25% through the chimney, and are left with 8640*0,75 = 6480 Cal. Now, you have 200 liters of water, so with those 6480 Cal, its temperature will rise by 6480/200 = 32,40ºC. But you need a rise of 55ºC, hence you need more gas... Exactly (55/32,4)*2 = 3,4 cu. m...
Thanks
° is not a unit. Use K instead.
Apart from that, it looks fine (but I really don't like "Cal" for kcal).
1. How does carbon gas heat water?
Carbon gas, also known as carbon dioxide (CO2), can heat water through a process called combustion. When carbon gas is burned, it releases heat energy, which can then be transferred to water through a heat exchanger.
2. Is heating water with carbon gas safe?
Yes, heating water with carbon gas is generally considered safe. However, it is important to ensure that the combustion process is properly controlled and ventilated to prevent any potential hazards.
3. Can carbon gas be used in all types of water heaters?
Yes, carbon gas can be used in various types of water heaters, including tankless, storage tank, and solar water heaters. The method of heating may differ, but carbon gas can be utilized in all of these systems.
4. How does using carbon gas compare to other methods of heating water?
Compared to other methods of heating water, such as electricity or natural gas, using carbon gas may be more cost-effective and environmentally friendly. However, the efficiency and effectiveness may vary depending on the specific system and its maintenance.
5. Are there any disadvantages to heating water with carbon gas?
One potential disadvantage of heating water with carbon gas is the production of carbon monoxide (CO), which can be harmful if not properly vented. Additionally, the availability of carbon gas may be limited in some areas, making it less practical or feasible for use.
