Homework Help: Heavyside convolution
  1. Feb 4, 2012 #1
    Calculate the convolution
    [tex] (\theta \ast \theta)(x) [/tex]
    2. Relevant equations
    Convolution is defined as:
    [tex] (f \ast g)(x) \equiv \int_{-\infty}^{\infty} f(x - y) g(y) \ dy = \int_{-\infty}^{\infty} f(y) g(x-y) \ dy [/tex]
    3. The attempt at a solution
    I know this is probably easy for many but I'm really baffled with the outcome. Here we go
    [tex] (\theta \ast \theta)(x) = \int_{-\infty}^{\infty} \theta(x - y) \theta(y) \ dy = \int_{-\infty}^0 \theta(x - y) \underbrace{\theta(y)}_0 \ dy + \int_0^{\infty} \theta(x - y) \underbrace{\theta(y)}_1 \ dy [/tex]
    [tex] = \int_0^{\infty} \theta(x - y) \ dy = y \theta(x - y) [/tex]
    However my result should be
    [tex] = y \theta(y) [/tex]
    Gawdemmit, I can't spot my fault here. What am I missing?
    Cheers.
  3. Feb 5, 2012 #2
    vela
    Staff Emeritus
    Education Advisor
    Your integration with respect to y can't end up with a y in the result. How are you getting to your final result?
  4. Feb 5, 2012 #3
    You're right, It should be
    [tex] \int_0^y \theta(x - y) dy [/tex]
  5. Feb 5, 2012 #4
    vela
    Staff Emeritus
    Education Advisor
    The upper limit should be x, not y, because the step function equals 1 only when x-y > 0. Remember y is a dummy variable in the convolution integral. You should end up with a function of x.
  6. Feb 5, 2012 #5
    [tex]
    \theta \ast \theta (x) = \int_{-\infty}^{\infty}{\theta(x - y) \, \theta(y) \, dy}
    [/tex]
    Look where the argument of each of the functions becomes zero:
    [tex]
    y = 0, \ y = x
    [/tex]
    So, if [itex]x < 0[/itex], the intervals in question are:
    [tex]
    \begin{array}{c|c|c|c|c|c|c|c|}
    & -\infty & & x & & 0 & & \infty \\
    \hline
    \theta(y) & & - & - & - & 0 & + & \\
    \hline
    \theta(x - y) & & + & 0 & - & - & - &
    \end{array}
    [/tex]
    Since the Heaviside step function is zero whenever its argument is negative, we must have to "+" in both rows for the product to be non-zero. As you can see, this is never the case for [itex]x < 0[/itex].
    Now, suppose [itex]x > 0[/itex]. The intervals in question are:
    [tex]
    & -\infty & & 0 & & x & & \infty \\
    \hline
    \theta(y) & & - & 0 & + & + & + & \\
    \hline
    \theta(x - y) & & + & + & + & 0 & - &
    \end{array}
    [/tex]
    Now, the only interval when the product is non-zero is [itex](0, x)[/itex]. Thus, the convolution integral reduces to:
    [tex]
    \theta \ast \theta(x) = \left\lbrace \begin{array}{ll}
    0 &, x < 0 \\
    \int_{0}^{x}{d y} &, x > 0
    \end{array}\right.
    [/tex]
    I think it is pretty straightforward to evaluate the remaining steps, and use the definition of Heaviside's step function to encompass both cases under a single expression.
  7. Feb 5, 2012 #6
    Thanks guys I got it now.
    The way you laid it out Dickfore makes it really clear but it unnerves me to solve an integral like that using just simple logic. I usually go straight for some rigorous integration rules and tricks instead of just visualizing the problem.
    Thanks again
Loading...
Similar Threads for Heavyside convolution
General solution for the heat equation of a 1-D circle
