Football Release Height: 19.0m/s, 30.5deg, 35.0m Away
  • Thread starter brunettegurl
  • Tags
    Height
In summary, the conversation discusses using kinematic equations to calculate the initial height of a football thrown by a quarterback. The quarterback throws the ball with an initial speed of 19.0 m/s at an angle of 30.5deg above the horizontal. The pass is incomplete and the ball lands 35.0 m away from the quarterback. The equations used include Vy= Vknoty - gt, y= Voyty2-0.5gt0.52, and xmax= v0xttot. The conversation also addresses the importance of considering the vertical starting velocity when solving for the initial height.
brunettegurl
138
A quarterback throws a football with an initial speed of 19.0 m/s at an angle 30.5deg above the horizontal. Unfortunately, the pass is incomplete and the football drops to the ground, 35.0 m away from the quaterback. From what height was the football released? (no diagram provided)
Vy= Vknoty - gt from which we get ttot= [tex]\frac{2Vosin\vartheta}{g}[/tex]
from the equation y= Voyty2-0.5gt0.52 we get hmax= v02sin2g[tex]\vartheta[/tex]/2g
so to figure out far it goes i used the equation xmax= v0xttot where it wld now equal vknotcos[tex]\vartheta[/tex](2*vknot sin[tex]\vartheta[/tex]/g) + distance it traveled and i wanted to know what i was doing wrong thanks :))
Not sure what you're doing here. You set v_y=0 when the ball touches the ground? This is not true for if there had been no ground it would have continued to fall.
You know the ball traveled a distance of 35 meters in the x-direction. So you can calculate how long it took for the ball to reach that position with [itex]x=v_x t[/itex]. Knowing the flight time you can solve the initial height by using [itex]y=y_0+v_0 t-1/2 gt^2[/itex].
why wld the velocity be v0 and not Vy??
It's not I just listed the general kinematic expression for a falling object. In your case the vertical starting velocity is v_y.
thanx :))
1. What is the release height of the football?
The release height of the football is 19.0 meters.
2. What is the release speed of the football?
The release speed of the football is 19.0m/s.
3. What is the release angle of the football?
The release angle of the football is 30.5 degrees.
4. How far away is the football released from its target?
The football is released 35.0 meters away from its target.
5. What are the units of measurement used for the release height, speed, and angle?
The release height and distance are measured in meters, while the release speed is measured in meters per second and the release angle is measured in degrees.
