Solve for Tree Height: tan45=h/22
In summary, the conversation is about finding the height of a tree using trigonometric equations. The solution involves using right triangles and solving for the height using various given values. The final answer is 17.618 meters.
chawki
506
see attachments.
what is the height of the tree?
It seems that tan45=h/22
h=22*tan45
h=22m
No. You need to look at right triangles. tan45o=h/d where d is the perpendicular distance from the endpoint to the tree.
By the way, you might want to call the top end of the tree height h1 and the bottom end h2 such that h1+h2=h (the total height of the tree).
like that ?
sin17=x/22
x=6.432m
tan28=z/y----(1)
we search y.
222= x2+y2
y2=222-x2
y2=484-41.37
y=21.038m
(1) <=> z=y*tan28 = 21.038*tan28 = 11.186m
height of tree = x+z = 6.432+11.186 = 17.618m
chawki said:
like that ?
sin17=x/22
x=6.432m
tan28=z/y----(1)
we search y.
222= x2+y2
y2=222-x2
y2=484-41.37
y=21.038m
Looks ok to me.
1. What is the formula for solving tree height using tangent?
The formula for solving tree height using tangent is tanθ = opposite/adjacent, where θ is the angle of elevation and opposite is the height of the tree and adjacent is the distance from the tree to the observer.
2. How do I determine the angle of elevation for a tree?
You can determine the angle of elevation for a tree by measuring the vertical distance from the ground to the top of the tree and the horizontal distance from the tree to the observer. Then, use the inverse tangent function to calculate the angle.
3. What is the value of tan45?
The value of tan45 is 1. This means that the opposite and adjacent sides of a right triangle are equal in length when the angle is 45 degrees.
4. How do I measure the distance from the tree to the observer?
You can measure the distance from the tree to the observer using a measuring tape, ruler, or other measuring tool. Make sure to measure the horizontal distance, not the diagonal distance.
5. Can this formula be used for any tree?
Yes, this formula can be used for any tree as long as you accurately measure the angle of elevation and the distance from the tree to the observer.
