Height reached by an object
nos
40
Hello everyone,
I was playing around with some equations regarding air resistance. I tried to calculate the height that is reached by an object that is projected vertically into the air. However something seems to go wrong when integrating.
Starting with the equation of motion
\begin{align*}
m\frac{dv}{dt}=-mg-kv^2.
\end{align*}
Setting \begin{align*}a=\sqrt{\frac{km}{g}},\\
v(0)=v_0.
\end{align*}
Then the solution to this differential equation is
\begin{align*}
v(t)=\frac{\tan{(\arctan{(av_0)}-gt})}{a}.
\end{align*}
Then the time it take to slow the object to a standstill(where it reaches maximum height) is
\begin{align*}
t_{end}=\frac{\arctan{(av_0)}}{g}.
\end{align*}
So the distance traveled in this time can be found by integrating the velocity function over this time.
\begin{align*}
h&=\int_0^{t_{end}}\frac{\tan{(\arctan{(av_0)}-gt})}{a}dt\\
&=\frac{1}{ga}(\ln{\cos{(arctan{(av_0)}-gt_{end})}}-\ln{\cos{(\arctan{(av_0)}}}.
\end{align*}
I did not even bother going through with it, it's going to come out negative.
I'm not actually sure this is the right antiderivative. Or maybe I lost a minus sign somewhere. I can't spot it.
Answers and Replies
12,736
Something went wrong with units, the formulas cannot be right.
23
How are you sure that you can solve this analytically? I think it can only be solved numerically. I could be wrong though.
vanhees71
Insights Author
2021 Award
20,106
10,846
It's solvable by separation of constants:
$$-\frac{m}{mg+k v^2} \mathrm{d} v=\mathrm{d} t.$$
Because we have
$$\int \mathrm{d} v \frac{m}{mg+k v^2} =\frac{1}{g} \int \mathrm{d} v \frac{1}{1+(\sqrt{k/(mg)} v)^2} = \sqrt{\frac{m}{gk}} \arctan \left (\sqrt{\frac{k}{mg}} v \right),$$
we get
$$\sqrt{\frac{m}{gk}} \left [\arctan \left (\sqrt{\frac{k}{mg}} v \right)-\arctan \left (\sqrt{\frac{k}{mg}} v_0 \right) \right]=-t.$$
This gives you ##v(t)##. Integrating once more gives ##h(t)##.
nos
40
This is the correct answer for the velocity function. I realised I missed a constant and instead \begin{align*}
a=\sqrt{\frac{k}{mg}}\end{align*}
So \begin{align*}
v(t)=\sqrt{\frac{mg}{k}}\tan{\Big[\arctan{\Big(\sqrt{\frac{k}{mg}}v_0\Big)}-\sqrt{\frac{gk}{m}}t\Big]}
\end{align*}
Integrating this
\begin{align*}
h&=\sqrt{\frac{mg}{k}}\int_0^{t_{end}} \tan{\Big[\arctan{\Big(\sqrt{\frac{k}{mg}}v_0\Big)}-\sqrt{\frac{gk}{m}}t\Big]}dt\\
&=\frac{m}{k}\Big[\ln{\cos{0}}-\ln{\cos{\Big(\arctan{\big(\sqrt{\frac{k}{mg}}v_0\big)}\Big)}}\Big]\\
&=-\ln{\Big(\sqrt{1+\frac{k}{mg}v_0^2}\Big)}.
\end{align*}
This will give me a negative height, which is impossible.
12,736
The cosine of something cannot exceed 1, so the logarithm of it has to be negative or zero. The second last line is always zero or positive, not sure what happened afterwards.
nos
40
Oh right thanks, so the second last line is positive. I tried to simplify the answer a bit more and this is where I think made a mistake.
Imagine a triangle with angle θ.
\begin{align*}
\theta=\arctan{\sqrt{\frac{k}{mg}}v_0}
\end{align*}
Then the opposite and adjacent sides are
\begin{align*}
O&=\sqrt{\frac{k}{mg}}v_0\\
A&=1
\end{align*}
Then the cosine of this configuration must be \begin{equation*}\cos{\theta}= \frac{\sqrt{1+\frac{k}{mg}v_o^2}}{1}\end{equation*}
Edit: I see this is the secant and not cosine haha, so that will account for the minus sign :) thanks for replying
12,736
In the last equation there is a square root missing and you have to swap numerator and denominator. Taken out of the log that gives a factor -1/2 which makes the result positive.
wrobel
Insights Author
986
839
the formulas could be much shorter
Let ##s## be the path, ##\dot s=v##. Then equation
mdvdt=−mg−kv2.​
takes the form
##m\frac{dv}{ds}v=-mg-kv^2## and
separating variables we get
$$s-s_0=\int_{v_0}^0\frac{mvdv}{-mg-kv^2}=-\frac{m}{2k}\ln(mg+kv^2)\Big|_{v_0}^0$$
Likes vanhees71, nasu and Delta2
Related Threads on Height reached by an object
