Homework Help: Height with EPE question.
  1. Jan 28, 2009 #1
    A .250 kg block on a vertical spring with a spring constant of 5.00 x 10(3) N/m is pushed downward, compressing the spring .100 m. When released, the block leaves the spring and travels upward vertically. How high does it rise above above the point of release?
    Mass = .250 kg
    Distance = .100m
    Spring Constant/K = 5.00 x 10(3) N/m or 5000 N/m
    2. Relevant equations
    Have to find EPE I think, EPE = 1/2 K(^x)2....the ^ is a triangle which in this equation is change in length.
    Maybe use mgh
    3. The attempt at a solution
    I got EPE which was 25. I think that to find h you can use formula mgh. I forgot how to do this but I recall doing something like (.250)(9.81)(h), 2.45(h), and you take the square root of 2.45 and that is how you get h. Then in this problem h would = 1.60m. I really think this is wrong but it was all I could think of.
    Can someone please help me find the height? Or if I have the correct method please reply and tell me I did it right(don't think I did though)
    Thank You
    ~Patrick
  3. Jan 28, 2009 #2
    Kurdt
    Staff Emeritus
    All you have to do is equate the spring potential energy with the gravitational potential energy to find the height.
  4. Jan 28, 2009 #3
    So PE = the GPE and divide like...2.45(h) = 25..25/2.45...h = 10.2m
    Is this correct?
    Thank You
    ~Patrick
  5. Jan 28, 2009 #4
    Kurdt
    Staff Emeritus
    Equate just means setting one thing equal to the other. In your question you have set:
    [tex] \frac{1}{2}kx^2 = mgh[/tex]
    With some algebraic manipulation you can make h the subject and plug in the numbers.
  6. Jan 28, 2009 #5
    Okay, so I had done that, I'm pretty sure 10.2m is the answer than, can you confirm that though?
  7. Jan 28, 2009 #6
    Kurdt
    Staff Emeritus
    Yes, that looks good to me.
  8. Jan 28, 2009 #7
    Okay, thank you very much.
