Helical Electron Polarisation?
In summary, the conversation revolves around the topic of electron spin and its relation to helical polarization and chirality in quantum field theory. The discussion also touches upon the Higgs mechanism and the search for the Higgs-boson. There is a difference in behavior between left and right-handed chiralities, with only left-handed fermions feeling the weak interaction. Theoretical explanations and experimental evidence are provided to support these concepts.
Jacko
In what manner can an electron be said to be helically polarised?
:confused:
I have heard of spin-polarisation, but that should be strictly up or down shouldn't it?
helical polarization?
You sure you aren't referring to chirality (the position of momentum p compared to the position of the spin-vector). In QFT the four-fermion interaction of the weak force is described by the V - A-current. Basically this means that the fermionic current to which the massive gauge-bosons of the weak interaction couples, can be written as a vector and an axial (A) vector. This V-A structure arises when you apply the left-chirality-operator onto the fermionic current, calculating the left handed components of the invloved matter fields.
Keep in mind that only left handed chiralities "feel" (this means : are subject to) the weak interaction. Experiments show us that only fermions of left handed chirality will undergo weak (eg decay-processes) interactions. In other words : the massive gauge bosons of the weak interaction only couple to left handed fermionic currents (ie the matter particles with left handed chirality)...
marlon
I suspect Jacko means that the spin of the electron would be coaxial to its direction of movement.
Because of this difference in behavior between left and right handed chiralities and the fact that a mass-term in the Lagrangian mixes up these chiralities, all elementary particles are massless. Once the breakdown of symmetry has occurred (this means : the original symmetry of the Lagrangian is no longer respected by the vacuum or groundstate) mass is "generated" through interaction with the Higgs-field. Photons are always massless because they do not interact with the Higgs field. The reason for this is that after this symmetry-loss of the vacuum-state the "universal" U(1)-symmetry of elektromagnetism is still respected by both the vacuum and the Lagrangian. So photons do not "feel" this loss of symmetry because their U(1)-symmetry is still there...
You got to think of this Higgs-interaction as if a particle were moving through some kind of background that is originally uniform. When the particle appears in this Higgs-field the uniformity will be disturbed, yielding a higher density of Higgs-particles around the elementary particle. This higher density is the mass that is generated around the particle. This socalled Higgs-particle is also referred to as the Higgs-boson. Many Higgs-bosons together constitute a Higgs-field just like many photons constitute an EM-field. This Higgs-boson has not yet been observed.
marlon
So he is talking about chirality...
marlon
marlon
I'm new to this (the reasoning leading from electron spin to the Higgs particle), but it all seems quite hypothetical. How are people looking for this Higgs particle?
Could you clarify how a left-hand electron (which doesn't decay at all as far as I know) would behave differently than a right handed one?
Indeed it doesn't. Yet electrons are invloved into decay processes, just look at the electron in beta-decay. The difference in behaviour is exactly the fact that only left handed fermions feel the weak force.
About the search for the Higgs-particle : here is a nice site :
http://www.scienceblog.com/community/article2964.html
marlon...
The Higgs-boson is indeed speculative to some extent yet the Higgs-mechanism is the best thing we have up till now for explaining the mass of elementary particles. The discussion of mass mixing up the two chiralities is inherent to the theory of QFT and experiments have shown us that only left handed chiralities couple to the weak interaction. So all elementary particles must have ecquired mass after the spontaneous breakdown of symmetry. This is all proven and shown by experiments. Only the Higgs-particle is a well-considered "guess"... So this is not just some speculation...
marlon
Just a little precision : we're talking here about charged current, because right particles can couple to the Z boson (neutral current).
These different comportments can be "seen" when you derive the QED lagrangian. You will find different couplings between fermionic, Z and W fields.
As Marlon said, you will find that only the left handed fermionic fields are coupled to the W, but both right and left handed fields are coupled to the Z and the photon, with different amplitudes (which explain the different comportments even for the neutral current).
Welcome Major !
I disagree with your statements. You and Marlon seem to imply that there is a theoretical reason for the fundamental particles to be left-handed doublets and right-handed singlets. I wish I understand that, but I think it is wrong. Would right-handed neutrinos occur in Nature, they would be in the standard model as well. I fear that there is no well-justified deep theoretical reason for this bearkdown of chiral symmetry.
Chiral symmetry breaking in QED for weak coupling
J C Huang and T C Shen 1991 J. Phys. G: Nucl. Part. Phys. 17 573-581
Gauge bosons in an [tex]SU(2)_{right} \otimes SU(2)_{left} \otimes G_{leptonique}[/tex] electroweak model
You're right, there is no theoretical reason to that. I have just wanted to say that the different comportments between the two chiralities can be directly seen in the lagrangian.
So is it correct to say that all beta-decayed electrons are left-handed?
Like stated before, only left handed fermions are considered when interaction with the W+ and W- vector bosons is regarded. I am not talking about the Z-vector bosons...
marlon
yes, electrons involved in weak decays are left handed. The neutrino is either left or right handed so the corresponding neutrino current cannot be zero. this is the famous two-component theory of the neutrino created by Salam, Yang, Lee and Landau in 1957...
The reason for this is that given the left handed electrons invloved, the neutrino current must be written in a "certain" way invloving Dirac-matrices and so on. In this model you can "choose" certain variables to have certain values. Once chosen, the chirality of the neutrino is determined by anticommutation-relations that give you info whether the neutrino current is zero or not. So basically you "chose" the neutrino-chirality in such a way that the current is not zero, otherwise beta-decay would not be possible.
I know this sounds vague but this is quite advanced QFT-matter and the best way to study this is looking this up in books like Weinberg or Siegel...
http://arxiv.org/PS_cache/hep-th/pdf/9912/9912205.pdf (this is a difficult book, so you would need the necessary QFT-background)
marlon
marlon
Euuh, give the above site some time to load...
marlon
Yes, you should give this time, because it will be invaluably rewarded :approve:
Siegel's "Fields" is incredible. Some people have expansive books of their own, which do not cover even half of this marvelous masterpiece.
Hi Humanino,
like i said, i went to Paris for opto2004. Marvellous technology, very interesting. You know, since i am studying applied physics right now i am totally into photonics and nanotechnology. I was really blown away by the state of the art technology that was presented there. Combine this with the many beautiful women in Paris and you know what i am talking about. We should really meet someday in Paris so you can show me the coolest places to visit...(i am not talking about the Eiffel tower here...)
marlon
Thanks for all your replys. Just to clarify, the reference to helical electron polarisation: produced by circularly polarised laser light on a gallium-arsenic photocathode.
From what I understood from marlon, electrons produced this way would differ according to whether the light is right-circular polarized or left-circular polarized. In one case, they could experience the nuclear weak force, but not in the other.
It then seems that whether they are weak-force enabled or not also depends on if they are shot out of the sample on the front side (where light is incident) or the backside (should be possible for a very thin sample).
Confirmation of this by someone would be appreciiated.
From what I understand, both types of electrons interact via the weak force (maybe only via neutral current) and leave in the same direction. I still don't quite understand how these eletrons are 'helically polarised'. Is it something to do with their intrinsic spin?
As far as I know, intrinsic spin and electron polarization are the same. If polarization is helical, it means exactly the same as the spin vector being in the same direction as the translation.
1. What is helical electron polarisation?
Helical electron polarisation refers to the spin orientation of an electron as it travels through a magnetic field. This spin can either be parallel or antiparallel to the direction of the electron's motion, and it is an important property in understanding the behavior of electrons in various materials.
2. How is helical electron polarisation measured?
Helical electron polarisation is typically measured using a technique called spin-polarized scanning tunneling microscopy (SP-STM). This involves using a scanning tunneling microscope to image the spin orientation of electrons on the surface of a material by detecting the changes in electrical current resulting from the interaction between the electrons and the microscope's tip.
3. What is the significance of helical electron polarisation in materials science?
Helical electron polarisation plays a crucial role in the understanding of materials properties, especially in the field of spintronics. By controlling the spin orientation of electrons, researchers can develop new materials and devices with unique properties, such as increased speed and efficiency in data storage and processing.
4. Can helical electron polarisation be manipulated?
Yes, helical electron polarisation can be manipulated through various techniques, such as applying an external magnetic field or using spin filters. Researchers are also exploring the use of topological insulators, which have a helical electron polarisation that is resistant to external disturbances, making them promising materials for future spintronic devices.
5. How does helical electron polarisation relate to other forms of electron spin?
Helical electron polarisation is a specific type of electron spin that occurs in materials with strong spin-orbit coupling. Other forms of electron spin, such as spin-up and spin-down, can also exist in these materials, but helical electron polarisation is unique in its helical shape and its potential applications in spintronics.
  • Chemistry
  • Quantum Physics
