1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Helmholtz Coils
  1. May 13, 2007 #1
    How do I take the first and second derivatives of the helmholtz equation? The equation is as follows:
    Bx= ((uR^2NI)/2) * ( [1/((x+a)^2+R^2)^(3/2) ] + [1/((x+a)^2+R^2)^(3/2) ] )
    heres what I have to prove
    First Derivative
    http://s199.photobucket.com/albums/aa160/stryker213/?action=view&current=First.jpg
    Second Derivative
    http://s199.photobucket.com/albums/aa160/stryker213/?action=view&current=Second.jpg
    2. Relevant equations
    3. The attempt at a solution
    I just started multivariable calculus so I'm not quite sure what to do. I tried to take the derivative with respect to x and treated the rest of the variables as constants. However, I believe that you would need to do the chain rule to figure this problem out. Any suggestions?
  3. May 14, 2007 #2
    malawi_glenn
    This is a one variable calculus problem. If you have taken those courses in one variable calculus, these two relations should be very familiar:
    https://www.physicsforums.com/attachment.php?attachmentid=10053&stc=1&d=1179119518
    I use always the first one, so this problem could be written as:
    constant * [((x+a)^2+R^2)^(-3/2) + ((x-a)^2+R^2)^(-3/2)]
    (you forgot one minus-sing in the denominator..)
    And now you just do the thing as usual:
    ((x+a)^2+R^2)^(-3/2) becomes : (-3/2)(2(x+a))((x+a)^2+R^2)^(-5/2) and then the same thing for the other term. Remember to do the inner derivate (Chain-rule).
    And yes, the second is just treat all other things as constants..
    good luck =)
  4. May 14, 2007 #3
    Hello,
    Just take first order and second order partial derivative of the equation.
    I obtained the results by some calculation.
    The first order derivative vanishes at x=0, which is consistent with the fact that some simple experiments reach approximate uniform magnetic field at the center of the two coils.
    The second derivative does not vanish at x=0.
    Regards
  5. May 14, 2007 #4
  6. May 14, 2007 #5
    malawi_glenn
    why?
    differentiate this one for example: whith respect to x, all other is constants.
    (d/dx){[(x+a)^2+ T]^(3/2)} = (3/2)*2(x+a)*[(x+a)^2+ T]^(1/2)
    You should probably practice a little bit more on how to differentiate a bit more complex functions with one variable, the product rule, the chain rule etc.
  7. May 14, 2007 #6
    malawi_glenn
    did you get it now? =)
  8. May 14, 2007 #7
    yes, I understand most of it now. Although, I am having trouble with finding the second derivative. I'm not sure if I should use the product rule or quotient rule, but I'm sure I can figure it out
    Thank you to everyone who responded to this thread.
  9. May 14, 2007 #8
    malawi_glenn
    you do the same thing, but now you have things like:
    (d/dx){(x+a)*[(x+a)^2+ T]^(-5/2)}
    And here we use the product rule OR the quotient rule, as I said earlier that I always uses the first one, it is the easiest to remember, so i always uses that one and think of the equatation(function) as a product, as x/t^3 = x*t^-3
  10. May 16, 2007 #9
    i have the same problem, and I just wanted to tell you guys this help was amazing. Thanks!
  11. May 16, 2007 #10
    malawi_glenn
    i hope stryker123 made it now.
    it is of high imoportance to master calculus and linear algebra in the world of phyics.
  12. May 16, 2007 #11
    This was actually a very easy problem, but just looks very intimidating, and takes some time.
Similar Discussions: Helmholtz Coils
  1. Helmholtz coils (Replies: 5)
  2. Helmholtz Coil (Replies: 1)
Loading...
